Tyler Pinkerton
To add, I'm not sure if they all have it or if it was just an option or after market stc, but the previous employer's short body panther had the easily removable pin for the front landing gear scissor link so that it could be safely towed by the idiots employed by Atlantic...Not meaning to sound snarky, but I wouldn't worry about assimilating the information. There's really not that much to assimilate, unless, perhaps, you have very limited light twin time. The most important benefit of the 350? You'll have a lot less heartburn. Mnemonic: PA 300 has 300hp engines. PA350 has 350hp engines. The 350 even has counter-rotating props, so you've got that going for you, which is nice... especially if you ever actually puke an engine on takeoff. Then again, if you add all the extra seats, the 350 is probably equally pathetic when heavy and hot. Memory Item: Don't puke an engine in a Navajo (unless you are well away from the ground and have lots of airspeed).
Killer gotchas: Engine Cowling Screws (Ensure secured), Nose Bag Door (Ensure closed. Also, don't ever leave open unattended), Performance Charts (Don't believe them and/or factor by 2x or .5x, accordingly), Heater (Be wary), Gear (Clean often lest it get stuck down), MaxWgt Changes/VG add-ons (load only to original book MTOW... and factor by .5x).![]()
If you have a similar pin, make sure it's in before you start up.
