NewsBot
Administrator
Allen Corporation of America Ft. Worth, Texas:<BR />Summary: Join a fast-paced flight operations environment as a Light Twin Instructor Pilot. You will be part of a flight operations team and conduct training and check flights within an established Light Twin /Single-Engine program. Aircraft utilized are both the PA-44 G-500/G-1000 and CE 172 G-1000 aircraft. Your skills and knowledge as a certified flight instructor will be utilized to deliver the provided curriculum to our customer, the Federal Aviation Administration. This is the ideal job for a certified flight instructor with ambitions to work within the FAA, or the broader aviation fields of Part 91, 135, or 121 operations. You will fly well-maintained and equipped aircraft that utilize autopilots and glass instrumentation while enjoying a quality schedule and a competitive salary.<br /><div> </div><div>ESSENTIAL DUTIES AND RESPONSIBILITIES: Specific tasks to be performed by the Light Twin Instructor Pilot include but are not limited to the following:</div>• Provide flight training and checking in the PA-44 and CE-172 aircraft.<br />• Conduct pre-flight and post-flight briefings covering essential topics such as weather, route of flight, departure procedures, normal/emergency procedures, and tasks to be<br />accomplished.<br />• Maintain a thorough knowledge of the aircraft systems, avionics, normal, and emergency procedures.<br />• Conduct all assigned instructional activities with an emphasis on safety, in accordance with our Safety Management System (SMS) program.<br />• As Pilot-in-Command, apply the principles of Crew Resource Management.<br />• Utilize teamwork, multitasking, task prioritization, effective communication, and time management skills. <br />• Complete flight-related forms as necessary. <br /><div>• Other duties as assigned.</div><div> </div><div>WORK ENVIRONMENT: Alliance Airport (KAFW) is a Class D airfield located beneath the DFW class B airspace. Other operations at Alliance include GA, corporate, flight schools, drone and military operations on any given day. IP’s enjoy a relaxed office environment between flights. The schedule is 4 days on, 3 days off, with typically 2 flights per day. Federal holidays are observed. The starting salary is $45,000 with benefits. </div><div> </div><div>PHYSICAL DEMANDS: The physical demands described here are representative of those that must be met by an employee to successfully perform the essential functions of this job. <br /><br />• Able to sit and work at the controls of an aircraft for extended periods of time.<br />• Able to stoop, kneel, bend at the waist and reach on a daily basis.<br />• Able to perform general flight operations activities on a daily basis.<br />• Able to lift up to 25 pounds occasionally.</div><div> </div><div> </div><div> </div><div> </div><div> </div><div></div><div> </div>
Continue reading...
Continue reading...
