Autothrust Blue
”…trusting ze process…”
You are referring to the pitch-lock gap, the actuation of which results in about a 1.5% increase in Np following a loss of oil pressure if memory serves. If any oil is left at all, then yes- the aux pump can be used to fx the prop.So you need oil pressure of some kind then, right? No oil pressure, aux pump fails, and/or linkage failure, the prop is stuck in whatever position this happens in, correct?
I have a feeling the props systems are identical or similar, with different names for the components. Short of a linkage failure, the 120 has the pitch stop gap that would turn it into a fixed pitch propeller basically. With complete loss of oil pressure to the propeller system and an otherwise functioning engine. The aux feather can over-ride this.
If not...do not reduce speed below 115 KIAS.
