Yeah, some airplanes have power levers that aren't even attached to the engines!Edit: some aircraft don't have friction locks accessible by the pilot.
I want to fly one of these airplanes. Luckily or friction locks work well.Yeah, some airplanes have power levers that aren't even attached to the engines!
I have a question about turboprops. I never flew any, so I'm clueless.
I was watching an air accident mayday series on that ASA E120 crash that killed a senator and a NASA astronaut. It was on approach to landing and the left engine had an issue and as it failed, the prop didn't go to feather. It went the other way, fully meeting the air head-on. That's a worst-case scenario for a failed engine propeller.
My question is, in a situation like that, can a pilot just cut all fuel to that engine, and then vary the power on the remaining engine (including pulling it to idle) and then just glide it in? I don't know, that video I watched made it sound like those E120 guys basically had no chance because the propeller failed in a position that was impossible to fly with. They entered a nose dive and impacted the ground.
For those wondering, this is to protect the engine, not the pilot/airplane/etc... If a piston engine is spring loaded to WOT, big deal. Generally if a turbine engine goes wide open, it either melts or otherwise comes apart.Concerning the two power levers on King Airs, do you realize that a fairly hefty spring is attempting to pull each one back to idle at all times? As with any spring, the further it is stretched, the more force it applies...in this case, a force trying to return the PL to idle.
TBM850 I flew did not have a friction lock. I held that damn power lever like a pencil though since it was my only one!Some airplanes don't have friction locks.
This is a design of the Bendix FCU. Later model PT6s incorporated a Woodward FCU.Why is there spring loading in the first place?
After a couple hundred hours in a 9L I never heard about this once. Makes me glad the Mits is a lot simpler in this regard.
Interesting. Neither the Bendix, nor the Woodward FCU on the Garretts have a spring return that I'm aware of.This is a design of the Bendix FCU. Later model PT6s incorporated a Woodward FCU.
Fun fact: The Bendix FCU would give you infinite power if the N1 input shaft broke.
Technically there is no V2 speed. It's Vyse or 121. Per the POH if a takeoff is continued after an engine failure at V1 or above V1:If you really want to see how a B200 can kill you quickly, run performance numbers for a summertime takeoff at 12.5. There is no balanced field requirement (because it's 1 lb. shy of the requirement). Everybody thinks it's a "go" airplane, but if V1/Vr is 95, it's can take a couple of miles to get to V2 and 35 ft. How's that 4,000 ft runway looking?There are no numbers in the AFM, but the Army C12 numbers using a VR of 110 or so are a lot better, but the accel-stop numbers increase.
You would be correct since this is a normal category airplane, there is no legal requirement to be alive at the end of the flight.
Marketing drove the entire development process of the 200 and even the 350 (Ground Low Pitch Stops anyone?)Ummm....
I get what you're saying, it's a <12.5, normal category aircraft. From what I understand, like the Vr and the Vmca values, there was a lot of smoke-n-mirrors/marketing input with the development of 200 performance section. Beech was competing with the Citation 500. They published some Part 25 performance charts in the process.
If you are not at max gross, it could save your life to use the published V2 speed. We had the chart taped to the overhead for Vr and V2 and Vref for 11-12.5 at 500lb intervals.Marketing drove the entire development process of the 200 and even the 350 (Ground Low Pitch Stops anyone?)
They wanted an airplane that would not require a type so that way people upgrading from the Baron or C90 could slide right in and not worry about a thing.
There are V2 speeds published but technically speaking it's Vyse. V2 from a regulatory standpoint is a Part 25 requirement. From the POH: V2: Take-off Safety Speed is the speed at 50 feet AGL (35 feet AGL with one engine inoperative.) Now I'm not disagreeing Beechcraft gave us V2 speeds but per the engine failure after take-off checklist, we're not supposed to use anything other than 121.
Who could've predicted dying of a plane crash while in the box ?
I actually like watching some of the other sims running and trying to guess what they're doing. I swore they were going to rip out of the floor sometimes during what had to be a crash!You've never had some of the sim partners I have!!![]()
On my last checkride in the 200 we actually played around a little bit with some stuff like what's actually worse the gear down or the prop unfeathered and also did some single engine climbs. Blue line vs the 108 for the weight we were at. Turns out the gear is a bigger performance loss than a windmilling prop and you get a significant climb increase at 108kias vs 121 for that weight. It was like ~300fpm to over 800.I agree with you from a theoretical (and philosophical) standpoint, but I'd be interested in seeing just what the climb rate and gradient difference would be between 121 and 115...
I actually like watching some of the other sims running and trying to guess what they're doing. I swore they were going to rip out of the floor sometimes during what had to be a crash!![]()
Reverse thrust is always the most obvious. At least with turbo-prop sims, specifically the Q400. Crashes are second (only because of some of the yelling you hear coming out of them). haha I remember watching a CRJ sim sitting in a left nose up position and then it slammed to the floor. I thought for sure the right side mounting points were going to rip from the floor! haha I was thinking dutch-roll recovery with no yaw-damper gone poorly...As the box appears to be diving as if it is a sewer cover being dropped from altitude: "That looks like an emergency decent."
