Roger Roger
Bottom of the list
Yeah, but it will NTS which is in effect very similarTPE-331 doesn't auto feather. Jetstream/Metro
Well that's what I mean though --- say it does go the complete opposite direction of feather. Say if feather means 100% into the wind, imagine the reverse failure with 2%, meaning the prop is flat and basically a full-face head on to the wind. Even if you cut the power to this engine, cut the fuel, and use the power on the other engine, is this survivable on an E120? Dash 8? Q400? And this particular King Air?
I guess I wouldn't know, being single engine we don't do NTS shutdowns ever.Won't do much until feathered. I didn't care for it.
Our Garrett machines are all single engine. Therefore we never do NTS shutdowns in training or for maintenance purposes. There are several ground checks we do both in the hangar and running and if you go flight idle at high airspeed you will get an NTS but we don't take let it NTS to 38% or wherever it is that you have to pull the feather handle by.Now I'm lost. You won't shut down with a failure SE?
No but it goes in the right direction, and if you did remove all oil pressure, it would go to feather. Ever forget to put it on the locks?TPE-331 doesn't auto feather. Jetstream/Metro
If you cut the fuel to a pt6, which will remove the oil pressure as well, the engine will eventually feather even if autofeather doesn't work... and at high power settings outside TO and landing is probably off anyways.Well that's what I mean though --- say it does go the complete opposite direction of feather. Say if feather means 100% into the wind, imagine the reverse failure with 2%, meaning the prop is flat and basically a full-face head on to the wind. Even if you cut the power to this engine, cut the fuel, and use the power on the other engine, is this survivable on an E120? Dash 8? Q400? And this particular King Air?
Knock on wood I've never forgotten the locks, though on pre and post mx runs we do a lot of intentional unlocked shutdowns. Also first time you kill one with the red knob (at least in a caravan) it's pretty shocking.Yes, everyone laughed at me.
Yours not rigged with a small space between fuel shut off and feather?Knock on wood I've never forgotten the locks, though on pre and post mx runs we do a lot of intentional unlocked shutdowns. Also first time you kill one with the red knob (at least in a caravan) it's pretty shocking.
Without it feathering it is as bad as a sewer cover in front of that engine, A=πr2.
A few years ago I worked an aerodynamics scenario if the prop didn't feather on a C421 and if I remember correctly it was something equivalent to 40 or 80 square feet of additional drag to the airframe.
Oh, it is, but you have to check the feather function once in a while too. Typically to prevent a really ugly smoky event we will get a normal purge going then yank the red knob.Yours not rigged with a small space between fuel shut off and feather?
Yes, but depending how tight your beta system is it might take 5 minutes to get there.No but it goes in the right direction, and if you did remove all oil pressure, it would go to feather. Ever forget to put it on the locks?
I have a question about turboprops. I never flew any, so I'm clueless.
I was watching an air accident mayday series on that ASA E120 crash that killed a senator and a NASA astronaut. It was on approach to landing and the left engine had an issue and as it failed, the prop didn't go to feather. It went the other way, fully meeting the air head-on. That's a worst-case scenario for a failed engine propeller.
My question is, in a situation like that, can a pilot just cut all fuel to that engine, and then vary the power on the remaining engine (including pulling it to idle) and then just glide it in? I don't know, that video I watched made it sound like those E120 guys basically had no chance because the propeller failed in a position that was impossible to fly with. They entered a nose dive and impacted the ground.
This is why the PT-6 is King. The issue on it is DON'T FORGET TO ARM THE AUTOFEATHER, because it cought me more than once in training on it on engine failure after takeoff and I was just waiting for it to kick in.... IIRC the big Turboprops have something called Reverse Torque sensing, and once that goes you're supposed to feather by hand. But then again, I haven't flown anything larger than a King Air 200.I have a question about turboprops. I never flew any, so I'm clueless.
