I have a flow chart, one sec.
(grumble--digs out 30 pound binder of lesson plans...)
Here we go.
Here is the standard decision tree WITHOUT a MEL.
During the preflight inspection the pilot recognizes inop instruments or equipment
Is the equipment requried by the a.c's equipment list or the kinds of equipment list? FAR 91.213(d)(2)(ii)? (Marked required in the POH)
---> if YES unairworthy call mx
if NO is the equipment required by the VFR Day Type certificate reqs of FAR 91.213(d)(2)ii? (DAY VFR Regs)
if NO is the equipment requried by and AD?
FAR 91.213(d)(2)(iv)
if NO is the equipment requried by FAR 91.205, (IFR min equipment reqs) 91.207 etc FAR 91.213(d)(2)iii) (IFR REGS)
If NO the inop equipement must be removed from the a.c (far 91.213(d)(3)(i) OR deactivated far 91.213(d)(3)(ii) AND placarded as INOP
v
Go fly.
Basically its a filter--if you can get to the bottom you can fly provided you remove it or deactivate it and placard it.
Now, with a MEL put an additional filter at the top of the stack...
During the preflight inpsection the pilot recognizes inop instruments or equipment
The Pilot checks aircrat's MEL (see example MEL below)
Is the inop equipment in the MEL?
---> if YES do what the MEL says and go fly.
if NO...
(repeat above)
Is the equipment requried by the a.c's equipment list or the kinds of equipment list? FAR 91.213(d)(2)(ii)? (See POH)
if NO is the equipment required by the VFR Day Type certificate reqs of FAR 91.213(d)(2)ii? (VFR required equipment)
if NO is the equipment requried by FAR 91.205, (IFR min equipment reqs) 91.207 etc FAR 91.213(d)(2)iii) (IFR Required equipment)
If NO the inop equipment must be removed from the a.c (far 91.213(d)(3)(i) OR deactivated far 91.213(d)(3)(ii) AND placarded as INOP
v
Go fly.
Here is a pic of an MEL I use with my students:
Say your flight schools/fbo's resident 737-100 has an inop thrust reverser....
well, you go to the MEL, find the entry on the left and side and do what it says on the right hand side--then go fly.
If the equipment is not on the left hand side anywhere in the MEL, then follow the decision tree for your flight.
cordially,
b
