Why? If you are on a flightplan, recieved clearence, and following it then ATC wont have to provide any seperation that they would not provide were you to have your radios working fine.
Two scenarios:
#1 - You are departing IAD. You are cleared to destination (somewhere on the Chesapeake Bay) via the CAP5 departure (3000' initially as published), vectors to DAILY, then as filed, you are to expect 15,000 ten minutes after departure. You depart runway 30 at IAD. ATC's normal routine is to vector you north of IAD, turn you southeast, take you north of DCA, and somewhere near Andrews you finally get cleared direct to DAILY. After switching to departure, you receive clearance to climb to 7,000. Your comm radios go scratchy, and then dead. You
squawk 7600, and ATC immediately expects you turn directly to DAILY to join the route along which you were cleared. A straight line from your current position to DAILY will take you across 3 different arrival streams, the BARIN1/COATT4 into IAD, the IRONS4/OJAAY1 into DCA and the OTT6 into BWI. As you climb from 3,000 to 7,000 and fly direct from the point of lost comms to DAILY, you cross the BARIN1/COATT4 arrivals that are descending on a northwesterly heading to join the 1L/R finals. After you wait your 10 minutes to elapse, you continue the climb to 15,000, and then cross the IRONS4/OJAAY1 streams, which are level over OJAAY at 10,000, and then on through the OTT6, which cross SABBI at 15,000 and descend on a northeasterly heading to cross OTT at 9,000.
SOMEWHERE along this line, airplanes will have to be moved out of the way.
#2 Same route, same clearance, same situation. You
squawk 7700 for one minute, then squawk 7600, all the while making your turn to DAILY. Same thing, SOMEWHERE along this line, airplanes will have to be moved out of the way.
Thats what I mean by it'll happen regardless of what you choose to squawk.
