Are you actually thinking that if someone else also has responsibility for somehting, it automatically means you don't?That's all it took. Thanks.
Then who's really responsible for vfr to vfr separation in class b? I'm assuming if two planes collide atc is off the hook?
"Don't do nothin' stupid. Don't hit anything."Also 91.13 for what I think everyone assumed was obvious.
Why not try to land with the hood on to?Is this real life?
According to your profile, you are an assistant chief flight instructor with over 5,000 hours. I know you have at least seen a FAR/AIM before. Where are the hidden cameras?
Just curious: When you are on an IFR flight plan, are you not looking outside for traffic, birds, etc? Because right now, I'm picturing you doing approaches on an IFR flight plan, single pilot, under the hood all the way to DA.
Why not try to land with the hood on too?
Im not going to play whos is bigger with you. The post was just a question to see if it was possible (a hole in the system), not that anyone would be stupid enough to do it. As mentioned before, when in Class B ATC is responsible for VFR to VFR separation, so then are you required to look for traffic. Thats all. According to everyone's responses, the consensus is that regardless of ATCs duties, the pilot is ultimately responsible. A simple question, which got a simple answer.Is this real life?
If Im in IMC and its ATC job to make sure I dont crash into someone, then yes I believe they are solely responsibleAre you actually thinking that if someone else also has responsibility for somehting, it automatically means you don't?
So, if there's a school crossing guard who doesn't stop you, you think you have zero responsibility if you run over a kid crossing the street?
What that roughly means is, "if you see it, you will endeavour to avoid it."When weather conditions permit, regardless of whether an operation is conducted under instrument flight rules or visual flight rules, vigilance shall be maintained by each person operating an aircraft so as to see and avoid other aircraft.
Ignoring the requirement to see and avoid other aircraft, which exists in all classes of airspace, the conduct you describe is surely careless or reckless...Im not going to play whos is bigger with you. The post was just a question to see if it was possible (a hole in the system), not that anyone would be stupid enough to do it. As mentioned before, when in Class B ATC is responsible for VFR to VFR separation, so then are you required to look for traffic. Thats all. According to everyone's responses, the consensus is that regardless of ATCs duties, the pilot is ultimately responsible. A simple question, which got a simple answer.
I would agree, but I hope everyone can see the point Im trying to make. In Class B ATC is responsible for traffic separation, but ultimately the pilot is, so why mention anything about ATC being responsible?What that roughly means is, "if you see it, you will endeavour to avoid it."
Because they are. And it's important (to me anyway) for a pilot to understand the degree of assistance once can expect.I would agree, but I hope everyone can see the point Im trying to make. In Class B ATC is responsible for traffic separation, but ultimately the pilot is, so why mention anything about ATC being responsible?
If you are in the clouds and cannot see, yes. But even in IMC, if you can see, it's your obligation to see and avoid. Perhaps you see a VFR-only limitation in 91.113(b) but it's not there.If Im in IMC and its ATC job to make sure I dont crash into someone, then yes I believe they are solely responsible
I've had a CFI certificate for 10 years; your question and immature demands for "proof" make me question whether or not you should be flying with students.Thanks to everyone who showed proof, and to those who havent, I really hope you dont and will never have a CFI cert
Once again Im not sure exactly where you get your "facts" from but its not the best course of action to just make things up. I dont know how you've been teaching, but as a CFI you should know that showing "proof" is stated multiple times in the FOI. Providing adequate instruction, Be consistent, and Correct errors with an explanation of what went wrong. Maybe you should do a bit of review yourself. But I cant really argue considering it looks like youve been doing just fine without the FOI for the last 10 years.I've had a CFI certificate for 10 years; your question and immature demands for "proof" make me question whether or not you should be flying with students.
