Flight Plan "Remarks"?
unless you do something off the wall like request BFE to direct ATL at FL450 in a Lear
I just flew with a guy like that. I called to pick up the clearance.
ATC: "Sir, did you file this flight plan?"
ME: "No sir, was the other guy. Everything ok?"
ATC: "nobody gets "direct" out of so cal. Go ask him to try again or suffer the wrath."
ME: "consider his hand slapped"
(Meaningful discussion with other pilot followed along the lines of "listen skippy I know this is your first REAL job after getting your commercial in a Kansas corn field but do you think that you could make an EFFORT instead of relying on all of the other Fltplan.com users to do your work for you?!)
I worked for a flight school with the callsign, "Sky Ventures". In the remarks section we always included, AVL=Sky Ventures, N123AB. It was helpful because instead of an N number, we'd list AVL24. We also operated in the DC SFRA, so we filed via DUATS each flight anyway. I trained my share of student pilots, but I feel like my greatest accomplishment as an instructor was not getting violated in connection with the SFRA.
I flew out of HEF instructing for about 2 years. I didn't really think the SFRA was as dramatic as everyone makes it out to be. As long as you are talking to ATC, get a squawk code and don't fly by the White House, you're good
The current version of the SFRA is not as bad as in the past. Remember ADIZ ver. 1.0? I'm glad those days are over.
I was cruising along from Leesburg to Bay Bridge one afternoon, doing all the things you described, and the powers that be still launched a Blackhawk after me. Apparently it was due to controller error. Give it enough time and you too will have any interesting story related to the SFRA.
So you WERE flying by the White House? Well no wonder then... :)
I started flying there from '08 to '10 so it had just changed from ADIZ to SFRA. I used to have to fly a photographer around IAD and all kinds of little spots in and around the Class B. Probably the most annoying flights of my life. He would give me a photo copy of a TAC with his "locations", and I would fax the fixes from AML (i.e. radial and distance) to Potomac. It never failed we would be flying from point A to B and he would see a random train or something stupid and want me to fly over it. I'm just like "uhh that isn't a scheduled stop..." and he'd say "oh just tell them (ATC) it'll only take a second". It was more of an annoyance for me that the controllers. The controllers, whether busy or not, would just say "roger, report on scene" whenever we would leave a location. But as long as I told them what we were doing they really couldn't care and would always give traffic alerts.
Note: ATC can only see like the first few characters of your remarks, to see the whole thing they have to type a seperate command which they aren't likely to do. I never have my remarks be more than say one word usually, "MEDEVAC", "INSTRUCTION", "LOCAL", "MULTI APPR" etc
This is not true, at least for center. If you have filed remarks, next to your route is a little yellow asterisk. When we click it, the first 50 or so characters are visible, at least.
Yeah, I hate it when I have to look on flightaware.com instead. When that fails, I'll probably just go VFR rather than find an AF/D. Or file direct :)
I kid, I kid... Well, not really.
In the terminal environment, at least with facilities that use strips, we only see the first 15 characters or something like that, but we can always request the rest of it from the printer if we're curious.
Even I knew that before I got my first "real" flying job.
This.
IS.
SOCAL!
We use the remarks section for permit numbers/PPRs/slots and so forth for international flights. Most ATC in the U.S don't seem to care about remarks but other parts of the world- it's a different story.
Now that I know ATC actually looks at them, I really want to put random crap in there and see if I ever get a comment.
IF NO ANSWER ON RADIO - TEXT ME 555-5555
RIDIN DIRTY
If your female co-pilot does this, then it is acceptable.
