Flight Plan "Remarks"?
rframe
pǝʇɹǝʌuı
What purpose does the Remarks box serve in an FAA flight plan form? Does ATC ever see that? Is there anything that's useful to add?
I've had instructors in the past who've wanted to put things like "practice instrument approaches" in the remarks section. I've always thought to myself that was somewhat pointless.
On a VFR flight plan, which has the sole purpose of alerting SAR if you dont show up, then I feel the only remarks that might be useful would further elaborate on a planned route or intent if flight couldn't be completed as filed.
On an IFR flight plan, I question if ATC ever sees the remarks so there is probably little of value to put in there?
But these are just my assumptions... can anybody clarify how that box might be more useful?
I believe you have to use the remarks box out here when you file to do pattern work at certain fields, but that's a local rule due to the SFRA here. Never needed it in TX when I flew there.
Only time I ever use it is to denote "Non RNP10" going into the WATRS or WATRS plus regions headed to the Caribbean,
Used to use it to identify the aircraft registration on fltplan.com so that I only had to have one airplane and one performance profile saved for the entire fleet, but they have since added a box for that.
We see them. The first I think 16 characters at least in terminal. MX test flight, multiple approaches, check ride etc are useful to add. It keeps us from sending you to your filed route out in East Jesus when all you really need is a pressurization check. The one time I saw checkride in the remarks I made absolutely sure the vectors were generous and easy and complimented the pilot on her skill on the tower handoff. I've seen a ton of RA(dar) VEC(tor) appreciated/equipped. That'll get you a sure shortcut with me. I've seen we love ATC in the remarks, or Merry Christmas during that season. Yes we see it.
Also, if you file via DUATS (I think that's the one) we see your full name autopopulated in the remarks. PIC John Doe etc. We have a guy that'll say "Hey John, turn ten left". "How do you know my name?" "Doe family reunion, I'm your third cousin, remember me?"
Usually means I don't get asked how the approach will terminate :)
Also useful to specify particulars like NO SID/STAR, or anything else "outside the box"
Could be useful if you're /G but technically can't use it for approaches because the database isn't up to date. I know I've put VFR GPS in the remarks when it was VFR conditions in case they wanted to give me direct.
Which brings me to my question... Does it piss you guys off if we file /G and put that we can't shoot approaches with it? Or does it not really matter.
I worked for a flight school with the callsign, "Sky Ventures". In the remarks section we always included, AVL=Sky Ventures, N123AB. It was helpful because instead of an N number, we'd list AVL24. We also operated in the DC SFRA, so we filed via DUATS each flight anyway. I trained my share of student pilots, but I feel like my greatest accomplishment as an instructor was not getting violated in connection with the SFRA.
Doesn't bother me at all, but there's a huge disagreement agency wide as to whether /A aircraft can fly en route direct, in the radar environment with a "VFR" GPS. I'm not saying there should be a disagreement, but there is.
Did they change the VFR rules for JYO when you were there? Don't have to file now if you're entering/exiting JYO and staying clear of the Class B. Just squawk 1226 out and 1227 in.
Yeah I was never sure. A couple times I just filed /U since I had an expired database, but the concensus seems to be you can still file /G but not shoot approaches.
We are still lucky enough to have real FAA FSS one floor up, otherwise our entire clearance request goes into the remarks for a online file, as they can't handle restricted non part 95 routes or 97 DP's and approaches.
I began flying out of JYO June 2001 and experienced the changes in VFR rules at JYO over the years. I still fly out of JYO occasionally and I'm satisfied with the current procedure.
for the portland area we use the remarks section for our planned approaches and whether or not it is a missed, T/G, or a F/S. Just to give the controllers an idea of what we are doing in some sort of order.
Here we see anything/everything in remarks that's put in there.
Captains name if given will show here as well as your ETE Info
I was under the impression that you could only use /G if your GPS was IFR compliant (which includes a current database). When I flew with an expired database, I never filed /G.
Well for what it's worth, I deal with air carriers all the time who file with RNAV equipment suffixes, and then say "unable" to an RNAV or GPS approach. I'm not sure exactly what's going on there, but it's nice for them to be able to accept direct clearances without interrogation by the controller.
Some times it comes down to OPSEC limitations. Might be enroute authorized, but not SID STAR APP authorized.
