ahw01
Rather Interesting... Nice typo...
http://www.faa.gov/regulations_poli...fm/go/document.information/documentID/1029348
I do believe that many airplanes with 3 axis YD's and no IRS may have the same issue...What a phenomenal design.
Sent from my XT1049 using Tapatalk
Nah, I was just being a pain in the ass .The joke, you missed it.
I'm curious why the AHRS don't have a non-GPS mode. I know our AHRS (yes, I realize it's sort of apples to bananas) doesn't care about GPS. From my limited understanding there's no reason either a MEMS or an RLG AHRS with a magnetometer needs GPS to get at least a good-enough magnetic heading. It'd be interesting to know the deep details behind this.I do believe that many airplanes with 3 axis YD's and no IRS may have the same issue...
Lat/long allows it to correct the Mag gates for position based errors. It's not that it won't function without, but reverts to a lessor state.I'm curious why the AHRS don't have a non-GPS mode. I know our AHRS (yes, I realize it's sort of apples to bananas) doesn't care about GPS. From my limited understanding there's no reason either a MEMS or an RLG AHRS with a magnetometer needs GPS to get at least a good-enough magnetic heading. It'd be interesting to know the deep details behind this.
Lat/long allows it to correct the Mag gates for position based errors. It's not that it won't function without, but reverts to a lessor state. I'm assuming the Phenom YD won't accept a reverted state, as the heading input would no longer be corrected?
Either way, with an FMS capable of DME/DME, and IRS or other position reporting system should prevent this from happening even with a loss of GPS, so- I would assume this only happens outside of VOR range, or there is a issue in the avionics
(Garmin Graphic)
My guess (again, I'm only familiar with a single, very primitive system) is that in the no-GPS "degraded mode" or whatever the AHRS throws an error code or message saying its degraded. Probably the same code for a variety of errors, some of which would be a good reason to kick the YD off, but whoever programmed that functionality didn't consider the effects of this particular error (which shouldn't prevent the YD from working) on the system. Still a pretty stupid chain of events though.Lat/long allows it to correct the Mag gates for position based errors. It's not that it won't function without, but reverts to a lessor state.
(Garmin Graphic)
Congratulations, you have discovered Phenom logic!Still a pretty stupid chain of events though.
No brakes for you!Congratulations, you have discovered Phenom logic!
