I know, my point is
Yea but having GPS issues shouldn't really mean anything for AHRS. I know I have flown this airplane without GPS signals and everything worked fine in green needles.
When we did green needle scenarios in the sim, there was no "reverting" of mag info that was displayed. AHRS worked as advertised.
I don't have access to the FSI cam, anymore but-
Anyways, the AHRS uses gps to determine its position for the mag. Field variation. If you loose both GPS and DME/DME you fall into AHRS -No Gps. (Mag north, not true north)
If you lose both GPS and DME position, the magnetic compas will no longer be corrected - setting invalid sensor data. This is all largely academic though, as the systems are all integrated, so invalid inputs to the AHRS is pretty much the same thing as an invalid input to the AFS.
If you happen to be in heading mode, and lose GPS position and DME position ( no indications) then the HDG information to the AFS may drop. If the Mag only info is split between the left and right, or, if it moves more than 6* per second. If it looses the heading input, it would cause a disconnect of the AFS if flying in HDG (and possibly other) modes.
With the YD off, there's a pretty good chance the airplane will Dutch roll. Most pilot attempts to correct Dutch roll lead to PIO, which can be extreme.
In reality it shouldn't happen, but, you know how that goes.
The Prodigy and G2000 were the first to allow DME/DME RMU for area nav, so, the plane will still have mag. Variation location, so, normally you shouldn't see anything happen
