pilotsav27
I appreciate the responses! This site is amazing, so thanks to all of you who make it that way!!
That's why we have Feet to meters charts in the airplane!!You're screwed when you're flying over a soviet bloc country and they assign flight levels in meters. Climb maintain, exactly, flight level 7000 meters.
That's why we have Feet to meters charts in the airplane!!No reason to make it harder on yourself than necessary!
And, just FYI...it's either 6900 or 7200 M for cruising altitudes, depending on direction (22,600' or 23,600').![]()
We've got about three copies in the cockpit.
Pansy. I can do it on the E6B.I am jealous. I can see myself break out the calculator and run the number.![]()
Another instance where having a relief pilot is fantastic:
"Hey, what's 7000 meters standard in 'Merican, Sparky?"
Do you have the "Meters" button on the 76?
You want some real commo hell, a place where clear/concise/correct simply does not exist. Go to DVT and listen to the myriad of TransPac planes.......
"Commo"?
Brother, I'm sensing a little too much BALO time in your past.
"Commo"?
Most ex-military guys I know refer to communications as Commo.
Do you find that particularly uncommon?
In the AF, our ground guys use commo, while in the air it's "comm." As an A-10 FAC background guy, I spent a fair amount of time attached to the Army as an ALO/Ground FAC, controlling airstrikes while attached at the BN level. The Army-ism of commo has stuck more than the AF side of comm, and it often shows.
Hacker happened to notice that. That I'd spent a little too much time riding an M-113 or an M-998.
Interesting.
Well, if you have been attacheded to Army units then you know that we use "Commo" for land, sea, and air!![]()
