Boris Badenov
This is no laughing matter.
Isn't it bad enough...
No, Gulley, it's not bad enough, but I suppose it will have to do. For now!
IBut you're the one who called him a creepy old man, not me!
first class was sold out on my leg to ATL. Now I have to sit next to people like you in the steerage.Boris Badenov said:No, Gulley, it's not bad enough, but I suppose it will have to do. For now!
There's some technical reasons why it's a bad idea, but I would have to dig up my glasses and velcro shoes to present those. The short version is that control margins and force gradients may be very different in the negative angle-of-attack regime than in the normal one. Most airplanes are not tested in that high-negative AOA area because there isn't a need to do so.
My argument (and obviously the contrarian point of view in this thread) is that airplanes aren't engineered for specific maneuvers, rather they're designed for certain maximum loads, gradients, pressures, accelerations, torque, etc - to cover a variety of maneuvers, turbulence, etc - at least from a Part 23 perspective http://www.ecfr.gov/cgi-bin/text-idx?rgn=div5&node=14:1.0.1.3.10#ap14.1.23_11589.a
If you're keeping a constant 1G load on the airframe, how would the fuel and engine lubrication systems 'know' they're inverted?Where it may come into play is that many fuel systems and engine lubrication systems won't work inverted, even if you are keeping a constant 1 G load on the airframe.
Please clarify, this would be something I need to know. Airplanes experience negative Gs a lot in turbulence and they keep running. Perhaps the AHRS tells the FADEC "This guy is getting a little sporty, please shut down and record this event in your trend monitoring as will I"(read in a british accent).Where it may come into play is that many fuel systems and engine lubrication systems won't work inverted, even if you are keeping a constant 1 G load on the airframe. That requires testing and, most planes won't undergo that sort of testing during certification, unless of course they are being certified to do that sort of thing.
There is an old promotional sales video on YouTube of a Bellanca Viking doing medium aerobatics, including snap rolls. All approved maneuvers for that airplane. @fholbert
All of this braggadocio about rolling airplanes solidifies my nagging paranoia about renting airplanes.
Well, it makes sense, look at all of the rental planes shedding wings and falling out of the sky! Can't believe you'd even consider it!
Aka, never go full retard?I think a more important debate is whether or not this should be shared on a public forum. The bravado or whatever want to call it, and notion that you can willingly break regulations because you are *I don't have the education to emote without using a curse word* super pilot is sad. Are you going to fall out of the sky for rolling a airplane, probably not. You want to brag about it, get off my lawn.
