A300Capt
Freight Dawg
Just curious, is there something about flying transport category aircraft that make the aerodynamics of crosswind landings different than general aviation aircraft?
The reason I ask is because it seems as though some posters who fly RJs and such act as if the "slip" and "crab and kick" methods are distinctly different. From everything I can tell, they're identical at the moment of touchdown...or at least they should be.
The wings will be in the same attitude, the upwind wheel will touch down first, the controls will be equally effective, speeds will be identical, etc. regardless of the method used. At least this is how it is for general aviation birds. In small planes, really the only distinction between the two methods is when the side slip is initiated, sooner or later...yet in both cases, the aircraft will be in an identical side slip at the moment of touchdown. I don't understand how things like scraping a wingtip or engine pod have anything to do with the crosswind technique used.
Does the larger mass or swept wings of airliners somehow change their crosswind handling characteristics?
It's basically the amount of bank used at the moment of touchdown regardless of method used. It's okay and preferable to land in a crab during xwind conditions when braking action is less than good such as wet/cluttered conditions. Obviously, the less the aircraft can be banked equals a greater crab that is required at touchdown.
Four engine aircraft (747, DC8, 707..etc) don't allow for much bank angle close to the ground whether you use the sideslip or kickout in the flare method. The outside pod engines will generally strike first and I know the DC8 is super critical here. I've been told you're limited to about 5 degrees of bank before an engine strike occurs. Those aircraft that sit on short gear legs and low hung wings (B727, DC9 and RJ's) could possible hit a TE flap or wingtip if banked too much so a slight crab is preferable. The B757 and A300 sit on tall gear legs and high wingtips that allow for more bank angle and clearance.
I prefer the kickout method and I suspect most 121 guys/gals use that method at least from my experience and observation. The sideslip down final method can be very uncomfortable for the passengers and is generally not used.
