So, in light of my "condescending" and/or fancy language responses, I'd just like to reiterate what I said in my initial response. You know, the response that engendered all the vitriol hurled upon me in this thread.Closed on approach. Open on Go-Around. Because: Amplitude of Heat.
If it's too hard to understand this and recall it at appropriate moments during the flight regime... Well then, I guess just avoid aviation and go back to whatever you do when you're not bungling up an aircraft and putting people or equipment at risk.
There's a checklist for both Approach/Landing and Go-Around. Like the two departures at SFO, BOTH of these checklists should be briefed BEFORE commencing the approach.
Here's the freaking A36 checklist:
cklist_pilot.indd
DESCENT
Altimiter ..................................................................... SET
Cowl Flaps ........................................................ CLOSED
Power .............................................. REDUCE AS REQ’D
to maintain below desired max KIASRPM first to 2000, then Throttle
Mixture............................................. ENRICH AS REQ’Donly enough for smooth operation
Engine Temperatures ...................................... MONITOR
Flaps and Landing Gear ................................. AS REQ’D
CRUISE - DESCENT
APPROACH
Landing Light .............................................................. ON
Fuel Selector Valve ...........................SEL FULLER TANK
Power ....................................................... 17”, 2300 RPM
Mixture....................................................... NO CHANGE
Flaps ............................................................ APPROACH
Airspeed............................................................ 110 KIAS
Trim ........................................................................... SET
Seat Belts and Shoulder Harnesses.................. FASTEN
Seat backs ............................ POSITION FOR LANDING
Writing Desk .....................................................STOWED
Avionics .....................CONFIRM SET FOR APPROACH
BEFORE LANDING
Landing Gear ...........DOWN; VERIFY 3 GREEN LIGHTS
Flaps ....................................................................... FULL
Airspeed.............................................................. 90 KIAS
Propeller .................................................... NO CHANGE
Yaw Damp.................................................................OFF
BALKED LANDING / MISSED APPROACH
Power .............................................................. MAXIMUM
Pitch................................ EST CLIMB ATTITUDE 100 Up
Positive Climb Rate.......................................ESTABLISH
Flaps ........................................................................... UP
Landing Gear .............................................................. UP
Cowl Flaps ............................................................ OPEN
If all you haters troll accusers are as good at reading as you imply you are, perhaps you can understand what the manufacturer said in its A/C Ops checklist (despite that checklist's several linguistic errors).
I NEVER condescended. I just presented. If you HATE the fact that I know what I'm talking about without having to revert to a reference doc, well, you KNOW what you need to do, right?!?
I'm just here to help... or, apparently... to royally piss folks off! (yes, Clarissa, that IS a grammatical faux pas. Never end a sentence a preposition with!)
Haven't INTERNALIZED!?!
I think NOT. I think I've internalized this stuff so profoundly that it JUST. PISSES. YOU. OFF!!!
