jon wilson
Pilot4Life
Hello I'm taking my commercial check ride next week. I just need some support. I'm very nervous about it but I know I will do good. I have the maneuvers down but the oral just seems like a lot of information to take in.
Best of luck!July 16 is the date of commercial check ride. Thanks for all of the help.
The best way to ease the nervousness is to make sure that you are well prepared. READ THE PTS, cover to cover, can't stress that enough. Make sure you know EVERYTHING that will be required of you on your checkride, and make sure that there is nothing in that PTS that you aren't comfortable discussing. Don't assume that your instructor has covered everything, take the initiative yourself to ensure that you are prepared. Use the checklist in the front, have all your documents neatly organized in a folder, with your endorsements in your logbook flagged with those little post it things so that it is as easy as possible for the DPE.
Don't forget the special emphasis areas in the front.
Good luck on your checkride, let us know how it goes.
CongratsPassed my check ride on 9/11
