PhilosopherPilot
Still fresh for some that post here.
Understand that. But sometimes it can be healthy to see the (slightly) lighter side 7 years later.
Uhh what?Hi, I move my airplane.
Standard vague post haUhh what?
As for write ups after heavy checks they will always be there due to the Waddington Effect. I saw this in the military where a perfectly good airplane would go into phase and come out a piece of junk.
Story of every Phase bird the ASB does or Theatre depot reset ever.
I mentioned The Waddington Effect.
http://blog.aopa.org/opinionleaders/2014/01/14/the-waddington-effect/
Vanity Fair? Seriously? That's where you go for information on aviation?Good article about outsourced maintenance...
http://www.vanityfair.com/news/2015/11/airplane-maintenance-disturbing-truth
But, but... depot makes it good as new.
I don't remember the name of the team that goes around checking airframes for cracks and corrosion, but they came to Bragg once and looked over some old UH-60As that use to belong to the 160th, but had just gone through Corpus and were "good as new". Almost all of them were found to have serious cracks.
I'll get to it after the 2016 Grammys best dressed celebrities.Did you bother to read the article? What about the one they did with Air France?
Why don't you read those two articles and then get back to me. Both pieces are excellent journalistic works.
I also saw a tail rotor installed backwards.... Not really sure how that happened since it would take more work putting that square peg through the round hole.
There won't be another accident like this one because the cause was so elementary. A pilot pulled back on the yoke at the first sign of the stick shaker, and then did it again three times. Who does that? Yes there were contributing factors, fatigue, chatter below ten etc. For all the analysis, and attention that this accident got, it comes down to one of the most fundamental aspects of flying, something we are exposed to in lesson one two or three, and have to be able to handle by our first solo.
The best thing that came out of this is now airlines take a closer look at failures, as this guy had multiple issues with aircraft handling throughout his flying career.
That would be pretty hard to not get a secondary. In every checkride I've done a secondary stall is a fail.I can tell you right now end of 2007 at a regional, for sim training, approach to stall in the landing configuration HEAVILY focused on "minimizing altitude loss." Which means we were taught to kinda "hold the yoke and ride the stick shaker" , max thrust / spoilers in , and even a *little* back pressure to ride the stick shaker and power out of the stall.
THAT is what the industry was teaching.
Absolutely insane, completely stupid, but you cooperate to graduate and do what they tell you.
At the first hint of a stick shaker, you need to do the max thrust / spoiler in (or whatever your callout is), but then reduce your angle of attack: push the damn nose down. #$%^ the altitude loss.
It doesn't matter if you're at 2,300 ft outside Buffalo or at FL350 northeast of Brazil over the Atlantic. You stall the wing, minimizing altitude loss doesn't mean jack when you fly a stalled wing all the way to the ground because airline training never emphasized nose down immediately.
It still gives me the chills to know I was taught in an airline environment to ride the stick shaker with slight back pressure and power my way out of a stall in a landing configuration.
It's ironic...the FO from 3407 said that very thing to me during our ALPA organizing drive. She wasn't in favor of joining ALPA due to the fact she had amassed thousands of accident free hours and didn't see the need for a union...a few months later, that would no longer be the case, sadly.
