bunk22
...old but good photo's
http://www.fighterpilotuniversity.com/alumni-house/alumni-news/cf-18-ejection
How exactly does the seat separate from the pilot's harness after ejection? I've always been curious about that.......
The pilot wears a harness that's connected to the chute pack in the top of the seat, they comvo as shoulder belts as well as the parachute harness riser connection. Post ejection, during seat-man separation, there's a reel that takes up slack behind the pilot's back and under his butt and boots him from the seat after separating the belts, etc. The former shoulder harnesses stay with the pilot and become the connection to his now inflating chute.
Different seats vary in their specific connections to the pilot, etc, but this is the basic function.
Ah, I think I understand.........but does the seat separate from the harness utilizing explosives or just a mechanical release?
Not sure what seat the CF-18 uses, but for the US built Hornet, basically the parachute is in the headbox, attached to the harness by the upper koch fittings. Before that deploys, the leg garters are supposed to automatically release leaving the pilot only connected to the upper fittings/parachute, and the lap belts which are connected to the seat pan (that has the raft and other stuff). There is an emergency manual release handle by your right thigh which will sever the garter connections in case this doesn't work as advertised.
It's mechanical. As AMG stated, his seat has leg restraints, while other seats don't. These are restraints around the lower calf designed to pull the legs into the seat so one's feet don't catch the canopy on the way up and out on some aircraft with tight quarters. Some seats have them, others don't, as they don't need them. The basics of function are the same, though how some of the seats do it specifically can differ.
Thanks Mike. It must be quite a sensation to have to use such a system--albeit better than the alternative!
So in overly simplistic terms there's almost two parts to the seat....a soft part (parachute, raft, etc.) and a solid part with the rockets?
Very interesting, btw. Thanks!
Its wild to watch videos of ejections. What are the physical effects on the body when one is ejected? Do they see injuries as a result of the ejections?
Still beats the alternative!Oftentimes, spinal injures....anywhere from minor to serious, and that's even with proper positioning and/or time to do that. Other injuries seen are flail injuries from arms not tucked, etc, and even from parachute inflation.
Now do the seats actually right themselves when the come out of the jet? In the link bunk posted, one of the captions is 'glad the seat gyros are working". So do the seats actually have a gyro that positions the pilot upright? I mean there must be right? Because the jet is at knife edge and the pilot is upright. What are the limitations to ejecting if the jet is in a roll?
I seem to recall that was a night training sorte and he had a partial electrical failure during high speed manuevers in a black hole environment.
