CF-18 ejection...
How exactly does the seat separate from the pilot's harness after ejection? I've always been curious about that.......
The pilot wears a harness that's connected to the chute pack in the top of the seat, they combo as shoulder belts as well as the parachute harness riser connection. Post ejection, during seat-man separation, there's a reel that takes up slack behind the pilot's back and under his butt and boots him from the seat after separating the belts, etc. The former shoulder harnesses stay with the pilot and become the connection to his now inflating chute.
Different seats vary in their specific connections to the pilot, etc, but this is the basic function.
Not sure what seat the CF-18 uses, but for the US built Hornet, basically the parachute is in the headbox, attached to the harness by the upper koch fittings. Before that deploys, the leg garters are supposed to automatically release leaving the pilot only connected to the upper fittings/parachute, and the lap belts which are connected to the seat pan (that has the raft and other stuff). There is an emergency manual release handle by your right thigh which will sever the garter connections in case this doesn't work as advertised.
The pilot wears a harness that's connected to the chute pack in the top of the seat, they comvo as shoulder belts as well as the parachute harness riser connection. Post ejection, during seat-man separation, there's a reel that takes up slack behind the pilot's back and under his butt and boots him from the seat after separating the belts, etc. The former shoulder harnesses stay with the pilot and become the connection to his now inflating chute.
Ah, I think I understand.........but does the seat separate from the harness utilizing explosives or just a mechanical release?
It's mechanical. As AMG stated, his seat has leg restraints, while other seats don't. These are restraints around the lower calf designed to pull the legs into the seat so one's feet don't catch the canopy on the way up and out on some aircraft with tight quarters. Some seats have them, others don't, as they don't need them. The basics of function are the same, though how some of the seats do it specifically can differ.
So in overly simplistic terms there's almost two parts to the seat....a soft part (parachute, raft, etc.) and a solid part with the rockets?
Very interesting, btw. Thanks!
Thanks Mike. It must be quite a sensation to have to use such a system--albeit better than the alternative!
It's there to use when needed, but it has it's drawbacks too. One can be seriously injured from all sorts of things such as body posture when the seat fires, etc. So long as one does everything they can to "help" the seat do it's job......as much as that is possible in uncontrolled cases......the seat will do all it can to help within its operating envelope.
The seat gets you up and away from the aircraft, and houses the life support gear you need after that (parachute, raft, beacon, etc).
A little face and knock on wood, no aviator has been killed during an ejection from the T-45A/C...now they have been killed post ejection but not from the seat.
Its wild to watch videos of ejections. What are the physical effects on the body when one is ejected? Do they see injuries as a result of the ejections?
Oftentimes, spinal injures....anywhere from minor to serious, and that's even with proper positioning and/or time to do that. Other injuries seen are flail injuries from arms not tucked, etc, and even from parachute inflation.
Still beats the alternative!
Now do the seats actually right themselves when the come out of the jet? In the link bunk posted, one of the captions is 'glad the seat gyros are working". So do the seats actually have a gyro that positions the pilot upright? I mean there must be right? Because the jet is at knife edge and the pilot is upright. What are the limitations to ejecting if the jet is in a roll?
There are limits to the envelope. Every TMS (Type Model Series) has a NATOPS with charts that show the limits in altitude, speed and AOB of the seat.
A good friend of mine was killed in a T-38 ejection. It was low speed and low altitude but I think the final report was that my friend and the instructor collided in the ejection. Both were fatally injured.
