CF-18 ejection...
A good friend of mine was killed in a T-38 ejection. It was low speed and low altitude but I think the final report was that my friend and the instructor collided in the ejection. Both were fatally injured.
Was that 4 or 5 years ago? I remember there were 2 fatal -38 mishaps in the span of a week or so back then. One of them ended up being reverse rigged ailerons and they basically departed controlled flight on takeoff because of it. Think I heard they attempted to punch out. Sorry to hear that regardless.
Yeah my friend was in one of the T-38 crashes. The aileron issue was at Columbus IIRC.
My friend was the accident at Sheppard that I believe was attributed to pilot error.
Denny White, who was Noodle's WSO on this day, had his leg slip over the side of the seat pan, and his leg was essentially ripped off. They found a boot print on the side of his helmet.
The problem there is that the T-38 does not (or, did not before an ongoing modification to change the seats) have sequenced ejection seats. Each fires individually, so those mid-air collisions between seats can happen.
I seem to recall that was a night training sorte and he had a partial electrical failure during high speed manuevers in a black hole environment.
It wasn't an "electrical faulure" per se, just the symbology in the HUD froze. The HUD video is driven by a 1980s-tastic computer, so just like your PC can freeze, sometimes the HUD video freezes. When recognized, it's an easy problem to fix. Because it was night, out over the ocean, and the HUD was frozen, Noodle didn't realize that the airplane had been slowly rolling over, pitching down, and speeding up.
He noticed significant wind noise over the canopy (which is usually associated with going at high indicated a/s), which prompted him to crosscheck his standby instruments.
He recognized he was in an unusual attitude and descending rapidly, and made a split-second decision to eject.
IIRC in the special on it he was attempting to do a Steep turn. During the maneuver he noticed a lot of wind noise which only happens north of 500+ knots. He had no outside reference and couldn't quickly decide which instruments were right so he ordered the ejection. Has he pulled the handles a second later the would have hit the water prior to ejection. It was a brutal ejection and he barely lived.
Mike and hacker on another note how does the o2 and emer o2 systems work. I've been reading a lot on the Alaska F22 crash. Does a bleed air leak shut down the o2 in all fighters? Do you then have to pull a key ring under the seat to start the emer system?
Depends on the source of oxygen. Older Hornets for example (not sure about early lot Eagles and Vipers) use LOX, and these systems are immune to bleed air problems. But on OBOGS jets, yes, any failure of the bleed air system (whether pilot commanded or automatic) will stop OBOGS from functioning. At that point, yes, there is a green ring on the seat, connected to the emergency oxygen bottle which when pulled, will initiate emergency o2 flow to the pilot/crewmember. I will say that I haven't had any major issues with OBOGS, but I have had more issues with it than I have had with LOX jets. Take that FWIW. It's a great system when it is working (especially for going on the road to fields that don't have a LOX farm), but there are a lot more moving parts to break.
Well, he was turning, but it wasn't a 'steep turn' in the sense that he was performing that as a maneuver in and of itself. He was flying as the wingman in a night 2 versus 2 air-to-air engagement. During those engagements you perform all manner of maneuvering -- there are no pitch or bank maneuvering limits at night. The only time we use the term 'steep turn' is when we are doing an instrument checkride and have to perform one to demonstrate proficiency.
When 85 degrees of bank and 3-4G is the standard method for turning the airplane, 'steep' is a relative term.
As ///AMG said, it depends on the system. In the F-15E, it is a Oxygen Generating System that is powered by bleed air, and then backed up by two emergency systems; a low-pressure accumulator type 'reserve' for the MSOGS, and a stand-alone high pressure oxygen cylinder that is part of the ejection seat.
The F-22 issue is unique to how the F-22's bleed air system works. Loss of bleed air in the F-15E sources aircrew oxygen from the 'reserve' bottle, and then ultimately forces the crew to manually switch over to the emergency cylinder. I don't remember how long the reserve system works in the 15E, exactly -- something on the order of 5 or 10 minutes, depending on how hard the crew is breathing.
To add to what hacker posted, I had a pretty unnerving spacial D incident a week or so ago. We were on goggles with pretty low ambient light, and I was coming out of a hard turn flying wing off my lead. I felt like we had rolled upright, but I was focused on scanning through the goggles and under them (essential for keeping your depth perception for safety of flight) while flying off lead. All of a sudden I see him in what appears to be a knife edge turn away from me, and for the life of me, I can't pull hard enough to keep in position....I'm drifting farther and farther away from him. I can see full planform at that point, with both red and green lights on the underside of his wings drawing further and further away. At that point, a lightbulb goes off in my mind and I realize something isn't adding up. I scan back to the HUD and realize he was roughly level, and I was directly below him, at about 110 deg of bank, rapidly descending through 10k (we were at 18k ish prior to that). Scared the crap out of me, though obviously I caught it and got the ground below my wings again. Don't think he had any idea until the debrief what had happened. I say this only because tactical flying at night (especially on goggles) is very challenging, even with practice. I know a guy (and his backseater) that are (last time I heard) still recovering from a supersonic nighttime ejection over the w291 doing air to air intercepts on goggles. Suffice to say that you do everything on goggles that you do during the day, with a few minor exceptions, and it can be very disorienting.
If stuff doesn't look right under NVGs in formation, make that quick crosscheck your instruments early, as you saw, it'll usually clue you in quickly. Don't overly rely NVGs, as they will screw you when you least expect it.
Personally I hate NVG's. I have been mildly disoriented every time I have used them thus far, even after messing around with distance to face and cant. I always find myself with my head cocked at weird angles trying to look under them, and honestly looking through them about 1% of the time. Most of the more experienced JO's swear by them, but agree that their initial experience was like mine. I guess it probably takes some time, but I agree Mike, IMO they are an extra sensor to be used to add to SA, but not as a single source. At my level of experience, I am much more comfortable flying form at night using the good old mk 1 mod 0 eyeballs. I think the thing that saved me was having been spacial disoriented MANY times while flying form in IMC or other marginal conditions, and being able to quickly recognize what kinds of sight pictures don't equate with reality. Reminded me of a time in -45's (think I posted about it before) when I felt like we were nearly inverted when in fact we were straight and level headed to the next navaid.
Yeah that too......or more like my head/neck in general. I probably haven't flown one nearly as long or you or Mike, but it is still uncomfortable. Then again, my O2 mask has been a horrible fit since I got it, which I am slowly trying to rectify with our awesome PR's (first good ones I've ever had). I know more than a couple guys who have paid out of pocket for old style masks, just to learn that they don't work with JHMCS....yay. The newish masks are truly horrible though. I have permanent red marks on my nose from it, but it is so loose around the chin that it is gushing air above 30k, no matter how hard I tighten down the little straps. That and the inner lip is like inside my mouth when it is tight enough to hold some semblance of a seal.
Having flown NVGs in both fixed wing as well as rotary wing, part of the problem for fixed wing is the lack of counterweights. But, the ones for fighters can't have counterweights, as they weigh the helmet down which isn't conducive to loaded maneuvering. AMG, you need to set your helmet and napestrap, and cinch down the chinstrap and such that you can tilt your NVGs to set them to a point where you can look through then outside, yet still easily look under them at the instruments without having to contort your face in odd ways. Your helmet will feel tighter on night missions if you set it as I mentioned above, but thats needed due to the weight sitting on the top front of it.
Is there a specific reason that the hose runs to the side on the MBU-20 in contrast to the older styles? Or is it just a design element?
There's an inhale and exhale valve, and they're interchangable.
I flew with a OD green /5P mask for the longest time.....one of the last before being forced to switch to the /12P. Full -20 with all the Combat Edge crap is just too much stuff to fly with, IMO; even though it's necessary.
The idea was to move the center of mass for the mask closer to the face, reducing the moment when under heavy G and making it easier for it to stay in place on the pilot's face.
There were some other design reasons related to the COMBAT EDGE system, which included an inflatable bladder in the back of the helmet that helped tighten down the mask under G, too.
Interesting. I know it's completely irrelevant to anything operational, but I kind of like the aesthetics of the older styles. But I'm sure the last thing they're worried about is my opinion! :)
Ah, that makes sense. Thanks!
I've tried that, and it's still a little weird.....I basically have them full forward (away from my face), and tilted up as much as I can stand; looking under isn't a problem, but it's just a blind spot basically anytime I have to look up above the canopy bow. Maybe next time I will sit down with one of the PR's and see what they have to say.
@ Hacker, yeah I think the USN/USMC has a different part #, but it's the same thing anyway essentially. I hear them on the center of mass idea, but the hose is too damned short, and the mask itself just doesn't fit my face. The mouth opening is too small, but the mask itself is too big and won't tighten down.
What I'd really like to see someone fly with is that crazy welder's mask looking helmet that made in the '90's that was laser safe. Man that would be a great helmet for BFM :)
