Cherokee_Cruiser
Bronteroc
Speaking with a BCP very recently that was specifically pointed out as not OK
Of course it's not okay. But pilot gonna pilot. And then cry for union representation after their own FAFO.
that’s interesting, so where’s the line? do you have to be x hours away from your base at all times during a rap? via car or bike or walking distance?Speaking with a BCP very recently that was specifically pointed out as not OK
it’s definitely risky but if the pilot didnt have any late shows or no shows why does the company care where you are?
Pilots being out of place on RES is bad, but if they didn’t try to run so thin on reserve pilots this wouldn’t be a problem.So now I’m going to get downgraded as well because we are somehow at Schrödinger's staffing levels. Overstaffed and understaffed at the same time![]()
Which bases?
There is only one day this week in my base where reserves are below required.
If you don't show up for work, you should get fired.
Considering the number of pilot CANX yesterday people need to sit short call in base. Or get fired if you don't show up. I'll gladly move up the seniority list.
July there will be more reserves? Since the ALV is higher?
I don’t know how that can be when literally every LC-C reserve gets converted their first day on and there is no limit to the number of conversions per pilot.Maybe not *soooooo* thin, but since all reserves start as long call it seems like there’s less short calls to fill in the gaps.
You’d probably know better than I would. Did you get a line for July?I don’t know how that can be when literally every LC-C reserve gets converted their first day on and there is no limit to the number of conversions per pilot.
The company fumbled and now they are trying to blame the pilots. No you failed to convert enough and manage staffing levels. Mets is a tool and that email shouldn't have been sent out.
Sure, we should always try to live below our means, but the sky is indeed not falling
Yep. Just speaking from the LAX dudes in my class who are on reserve, and the CAs in my pad, all day they just plan to get converted on the first day every time.You’d probably know better than I would. Did you get a line for July?
I was assuming reserves didn’t get used much because it’s actually going rather senior here.Yep. Just speaking from the LAX dudes in my class who are on reserve, and the CAs in my pad, all day they just plan to get converted on the first day every time.
Well it is summer time and you are in the mothership.I've selected "I do not want assignments" every day on reserve and I'm lucky if I make it one day without being called.
Edit: I’m also in a well staffed category which I’m sure makes a big difference.
