Roger Roger
Bottom of the list
I know. But Garrett. More HP and better fuel consumption than the blackhawk, easy access cowling, and the aero twin one is approved to 9062 lbs in known icing.Not the Garrett's on the conversions. PT-6A-42's
It would be nice to put the Garretts on because of all the advantages. I think the mod would pay for itself in cost savings alone especially when the company has about 30 of them.I know. But Garrett. More HP and better fuel consumption than the blackhawk, easy access cowling, and the aero twin one is approved to 9062 lbs in known icing.
I will be interested to see how the pt6 on the xp compares to the Garrett.I don't know a single installation where a garret doesn't outperform a pt6 in every category.
Try 10 starts in an hour....but other than that you are rightI don't know a single installation where a garret doesn't outperform a pt6 in every category.
You would be exceeding the starter limitation on the PT6 if you did more than what, 3?Try 10 starts in an hour....but other than that you are right
Wright's has an XP if I remember correctly. I can ask around and find out.I will be interested to see how the pt6 on the xp compares to the Garrett.
Well, that's one of the few reasons I can think of for balling up a caravan during a day VFR training flight in CAVU weather.Can anyone confirm the rumor that one wing came down some distance from the rest of the plane?
At Baron before my time we had one of the check airman do an actual engine shutdown, was then unable to get the engine started and they had to perform a forced landing on the road. Luckily, the airplane was undamaged ... until a 18 wheeler ran into it.Well, that's one of the few reasons I can think of for balling up a caravan during a day VFR training flight in CAVU weather.
I think that was his last day on the job. I feel bad for the student he was training.
I thought it was something like that but I couldn't realize how you could cook the engine with the EPL unless it involved starting the engine.Actually he used the EPL on a 135 leg conducting IOE and cooked the engine....the rest is as said
I have yet to actually fly a caravan, but I was taught in training that the EPL is perfectly capable of cooking the engine if not used with extreme caution, as you can exceed the safe metering rate for fuel increases.I thought it was something like that but I couldn't realize how you could cook the engine with the EPL unless it involved starting the engine.
Yeah, that would do it.At Baron before my time we had one of the check airman do an actual engine shutdown, was then unable to get the engine started and they had to perform a forced landing on the road. Luckily, the airplane was undamaged ... until a 18 wheeler ran into it.
Well, you come across as a bitter ex-employee but this has a ring of truth to it. Whether it has any bearing on this accident or not time will tell.. (It was an h6 training "practice" to take new hires near 3 step and do low altitude crap following the river to "check" their ability to fly low and fast while following river bends...to improve stick and rudder hand/foot and eye coordination)
I can think of several....one being screwing off at low altitude....yanking and banking.....wing hits the ground in a steep bank after you loose enough lift component...the plane cartwheels........the rest is history...so that would make sense as to why one wing would be a distance away. (It was an h6 training "practice" to take new hires near 3 step and do low altitude crap following the river to "check" their ability to fly low and fast while following river bends...to improve stick and rudder hand/foot and eye coordination)
