Here we go, and I don't take your response as a personal attack but a misguided one.
Regardless of what equations you can spew out, etc, the fact that you'll (for example) come out and tell Hacker how he should fly his F-15 and that he's doing it wrong is complete and utter arrogance of the worst kind.
I never told him his procedure was wrong and I never meant to imply it either. I even specifically said this in post #124 first paragraph. All I claimed was that his procedure, whether he realize it or not, is still controlling the aircraft the same way we discussed, he is operating within the bounds of physical law just like every other pilot.
I have over 7000 hours of many different kind of experience in many different arenas, are you going to tell me that with your 500 hrs you're somehow on par experience-wise?
Of course not, my experience doesn't go beyond the realm of piston singles and I know that. Correct me if I am wrong though but the discussion here is regarding teaching a pilot who has zero hours up to his private license in a piston single engine aircraft. The experience needed to do this lies in VFR single engine piston experience not in that of any other aircraft in any other realm.
I would even venture to say that experience beyond small aircraft and basic VFR only clouds and/or causes confusion when teaching a brand new pilot. I will get back to this later.
I know thats not what you want to hear, because (and not a slam here) your mind comes from "the land of absolutes".
There may not be absolutes throughout much of aviation, but we can get the basic training for a private pilot down to a decent solid method and make it fairly absolute. In fact, this already exists, the PTS is our list of absolutes. The methods used to teach to those standards vary, which for some reason I though I discussed here but actually did in another thread:
http://forums.jetcareers.com/1235974-post21.html
why are you knocking concepts before you've even tried them?
This is a poor assumption, I am actually surprised a little by this. I have tried them, I spent the first 200 hours teaching right out of the Jepp syllabus/my colleges syllabus. The result was getting a few guys through their solo and hating what I saw in my post solo students, stupid rudimentary errors. The method teaches by means of showing maneuver after maneuver with very little time spent linking it all together or teaching just basic flight operations (only about 2-3 hours on pure basics).
During those first basic flights so much information between preflight, checklists, and takeoff procedures are thrown at the student that by the time they are airborne their brain is already beyond its capacity to learn for the flight block.
I have spent the last 100 hours now on new ideas and concepts which I can't reveal but the outcome I believe is much better than the current. In fact I have one student who was taught the old way by me who I asked if he would let me take him back and show him a couple of these new ideas. The result is he actually flies the plane now instead of just operates it. He enjoyed the method so much that he has spent another 10 hours redoing all his basics with me per his request.
trying to reinvent the wheel
I think you missed my point, the wheel IMO needs reinvention, it needs a teachers design not a pilots design and the FAA obviously agrees or they wouldn't be studying it. We are trying to teach basic VFR pilots whose primary goal needs to be understanding and being able to operate an aircraft within the bounds of physical law. To this end I don't see that currently and I am basing this on those first 200 hours and somewhere in the range of 10 post solo stage checks and a few BFRs I have conducted. This whole thread reflects one of the major faults I am referring to, pilots crashing on a weekly basis because they stalled the airplane, an airplane that without their erroneous inputs would never stall. The airplane doesn't stall, the unknowing pilot makes it stall, maybe this isn't true in some of your aircraft but it holds true in any basic trainer and piston I have flown.
As promised back to the clouded judgment from extra experience. A fellow co-worker of mine teaches the takeoff like this: roll onto the runway and apply full power, check instruments in the green, airspeed alive, and scan between the instruments and outside till a rotate speed of 55 and then rotate, climb out again scanning airspeed/outside so you don't stall. Now I have had 3 of his students and they spend about 50/50 with their head inside vs outside on a typical rollout and climb out, this pattern stays true for the rest of the flight. What does the FAA say about this? The FAA says we should teach VFR primarily with reference to the instruments, 90 percent outside.
This instructor is a 2,500 hour pilot with almost 1000 dual given and another 1000 in 121/135 ops and loves instruments so it is no surprise he is teaching such a takeoff procedure. Many here might be thinking well what is wrong with that. What is wrong is it is a visual license and there is absolutely no need to teach a takeoff to a visual pilot with a rotate speed, that is teaching instrument reliance.
Instead I teach the takeoff as follows: taxi out and apply full power just the same, take a second to verify engine instruments, another second to verify airspeed alive (see its working), then eyes outside straight down the runway, as speed builds start to apply gradual back pressure bringing the glare shield to the horizon and when the airplane is ready it will fly, once airborne a sanity check of the ASI to ensure you are at a safe operating speed and then outside for the remainder of the climb setting a pitch attitude. I encourage anyone reading this to try this method and watch how much smoother the takeoff is and especially how much easier it is for a lower time, and even a higher time, pilot to perform than the one explained earlier.
The difference here might be subtle, but it applies through every single maneuver and every single action that I saw with the old method of flying. I won't explain or go into any details on it as it completely compromise many months of hard work on my part. I will say this, there is a better way, you will see.
Disclaimer: Not claiming my way is perfect as it is only in its infancy and ever evolving but I feel it has great growth potential and am very excited to share that with everyone here sometime soon.
Short summary: When it comes to teaching a private pilot the basics of flight the experience needed by the CFI needs to be with the basics of flight. A thorough understanding of basic concepts and straight forward VFR flight, experience beyond that only clouds the picture. It leaves the higher time pilot often forgetting the true basics because they haven't been thought about in years, it doesn't make them a bad pilot.
Some of the smartest and most experienced people in the world, in all fields including aviation, couldn't teach the basics of their field accurately to a 5th grade level, this doesn't mean they don't know their field. Everyone has likely had a professor like this in college.
