Not ideal. But what then? Go around? Now you’re continuing on your closure rate to that guy that just took off. That’s gonna make for a hairy situation on the radio. As both aircraft continue to close in on each other in the air.
Will admit, the idea of when to consider a runway occupied and initiate a go around, has become more ambiguous as time goes on for this exact reason.Not ideal. But what then? Go around? Now you’re continuing on your closure rate to that guy that just took off. That’s gonna make for a hairy situation on the radio. As both aircraft continue to close in on each other in the air.
No “emergency takeoffs”.
That had parts of Europe written all over it. I’ve been as low as (well, low) before another plane rotates and tower issued a landing clearance in FRA.
“FRA tower, Soiuthernjets 1-4-0, looking for a landing clearance”
“SouthernJets 1-4-0, NO, IF I CLEARED YOU TO LAND I WOULD HAVE SAID IT. YOU DO NOT HAVE A LANDING CLEARANCE YET. SOUTHERNJETS 1-4-0 CLEARED TO LAND”
(Not even kidding)
Generally, you will hear a "Continue" clearance when the runway is unsafe but expected to be safe by the time you arrive. I will also usually throw in a reason for the withheld clearance "traffic holds in position" and an "expect clearance 1 mile final" or something like that as a prompt for the pilots to remind me if they haven't already been cleared. It is required when an aircraft is positioned but not taking off when the Airport Surface Detection Equipment is either in limited mode or non-existent, or if it is fully functional but the weather is less than 800ft and 2sm. I personally use the technique if I have a vehicle conducting runway operations as well, though that is not required.I’ve gotten from tower before “continue”, while on approach and querying whether i was cleared to land and an aircraft was on the takeoff roll. With a landing clearance coming shortly thereafter. Of course, I come from years of Reduced Runway Separation, which was only 3000 feet between aircraft landing or a landing and a departure, (same aircraft type), and 6000’ for dissimilar aircraft type. So seeing aircraft on the runway I’m operating to isn’t a shock….though it should be. Another habit to break.![]()
That would not be okay if it implies what I think“Cherokee 91N go around expect long landing”
Idk, they used to use it in JNU with the 135 guys. You’d get too close and they’d tell you to go around, then clear you to land once the 207 or Cherokee ahead of you clearedThat would not be okay if it implies what I think![]()
Yeah, if it is two SRS Cat 1 aircraft you only need 3000ft. If the back is a cat 2 you need 4500ft. If the aircraft in front is closer than 3000ft you should be going around, not some trick of semantics, and if they are more than the above numbers, there is no need. When SRS Cat 3 is involved then only one aircraft can occupy the runway at a time. If you are flying a jet or large turbo prop you should definitely be going around in this situation.Idk, they used to use it in JNU with the 135 guys. You’d get too close and they’d tell you to go around, then clear you to land once the 207 or Cherokee ahead of you cleared
Listening to UA channel 9 the very first thing I heard in FRA was the approach controller tell S7 Siberian "Well then disconnect and fly manually, that is not an excuse for a nonstandard turn now you will be resequenced" in an angry tone hahaNo “emergency takeoffs”.
(Not even kidding)
