(Actual thing I heard from a passenger after he asked about how fast the 737 flies, SDF-MCO)
Used to fly there all the time in one of these:Don't remember EVAR having seen a Suthernyets 737 at SDF. Were you...fraternizing with The Enemy? @ATN_Pilot would like to have a word.
Even the fact that it has a pair of smoke belching JT8Ds strapped on it doesn't make up for the freaking powerpuff girls.Used to fly there all the time in one of these:
Pretty interesting review and some actual footage of a B-58 landing with a damaged gear assembly in 1961.
Way cool that they took off from KNFW in the evening, and stayed airborne all night making multiple air refuelings on a diversion to KEDW, in order to make a daytime emergency landing and not having to do it at night.
Similarly, in 1989, this B-1B Lancer had a nose gear malfunction on a mission out of KDYS near Abiliene, and was diverted to KEDW to make a nose-gear-up landing on Rogers Dry Lake bed. Interestingly enough, the Aircraft Commander of this B-1B who made the landing here, Capt Jeff Beene, was later in 2005 my Board President as Colonel Jeff Beene for the Accident Investigation (Safety) and I was his Investigating Officer (Investigator In Charge), for the B-1B gear up landing I and my team did the investigation on at Diego Garcia.
On this nose-gear-up landing, one of the big unknowns at the time was whether the overhead escape hatches above the 4 crew stations would jam or not, or even be useable, due to fuselage-top compression with the B-1 sitting on its nosecone and main landing gear. You can see in the video, the severe "flex" the top forward fuselage makes when the front of the B-1 finally comes down on the dry lake bed. As it turned out, the Offensive Systems Officer's overhead (seen open near the end of the video) was useable and the escape rope deployed, as well as the normal-entry bottom hatch. The fuselage flexed, but rebounded in order to allow the hatch to open. In the 2005 gear up landing, the bottom normal entry hatch was unusable since the jet was sitting on its belly, and only the OSO hatch was used there too, as the Defensive Systems Officer's hatch was found to be more difficult than normal to open following that accident.
About 2 years prior to the retirement of the B-58, was when SAC realized that they needed to switch from high altitude, to low altitude (under the radar) tactics for deep strike interdiction bombing by its B-52 and B-58 bomber fleet (and later B-1 and FB-111A fleet), with the B-47 being mostly, if not completely, out of service by this time. The B-58 was then tested to accept both conventional as well as nuclear ordnance, and tactics were changed to low-level/high speed interdiction as well as attack tactics for same. At this same time, there were provisions made for the possibility (which never occurred) of the B-58 being sent to Vietnam as relief for the constantly-worked B-52D/F/G crews rotating into and out of Thailand/Guam (the B-52H model never served in Vietnam, or even in Desert Storm). For that reason, at least one and possibly two B-58s were painted in the Southeast Asia camo pattern that the B-52D (and TAC F-111A) models used, with camo top and flat black undersides and tail, in concurrence with the low level testing. Pictures of the B-58 painted in the Southeast Asia camo exist, but are extremely difficult to find.
My uncle flew both the B58 and the B52 around this time. He did some cool stuff in his career and some stuff we think he did but was never documented or talked about. Tragically, he died in 1972 as an aircraft commander of a B52 during Linebacker 2. We only got his military records some years later and discovered all of this.
