On a serious note :
If you’re that RJ, with air stairs, are you evacuating down the air stairs?
They likely have no idea what kinda damage they have, likely cant imagine that the tail is gone. Are you waiting to hear from ARFF or reports from tower?
On a serious note :
That’s not really what I’m saying. Of course the air stairs could be used , but Does the fact that it has air stairs make it more likely that you (WWYD) would consider an “evac”. Would you (the collective you) evac in this scenario if you were the RJ crew.If there was a need for an emergency evac, such as a fire, it’s an exit like any other that would just have to be cleared. Don’t see an issue using it if a look out the main door exits can clear it of any active fire or other hazards besides the tail sitting on the ground. Luckily here, apart from the major structural damage, there appears to have been no other immediate danger.
Or if ARFF is taking a long time to get there… hear me out… use the air stairs for the FO to leave the aircraft and inspect the tail and decide what to do. It worked for Lufthansa!That’s not really what I’m saying. Of course the air stairs could be used , but Does the fact that it has air stairs make it more likely that you (WWYD) would consider an “evac”. Would you (the collective you) evac in this scenario if you were the RJ crew.
Some have cameras, but none of the cameras will show the wingtips. It’s basically “am I on the taxiway, where are the trucks, am I on centerline, cool look at me, I’m the king of the world standing on the tail!”
Besides, if you’re using a camera when spacing is questionable, it’s probably best to stop.
Yes, my question is, would you have ordered an evac in this case. And would the availability of air stairs help make that decision?Airstairs are a fully viable evac exit. I’ve personally seen them utilized on a taxiway evac of a 727 that had landed on RW 26L at PHX and had a hung brake that started smoking badly exiting the runway.
First it was sharks with freakin laser beams on their heads, now it’s whales with freakin laser beams on their wings??I’ve been flying/taxiing the 747 for 9 years and I still feel like I’m about to hit everything. Even if you look at your wingtips, it’s such a bad angle that you can’t really tell. I’d love to see some laser pointers that shine down to the ramp and if those clear an obstacle, the wingtips will.
Instead of boop the snoot, this is bump the rump.Boop.
Reading this in George Takei’s voice is excellent.Oh my!
No. Rear mounted engines with no fire indication, normal engine parameters, nothing out of the ordinary other than the tail damage, my vote is stay on.
LIke a horror movie "HES STILL OUT THERe!!"Especially if the Delta jet decides to do a 180 and come back to finish the job.![]()
