I'll try and run through it from memory:
One Pack is MEL so the highest you can go is FL250
The FA's medlink comm system is down so you have to use the SATCOM
Apparently they made the scenario harder and you had to use DTMF but that changed by the time I saw it.
Flight is ANC - SEA
There are reports of severe icing between 190-220
Right around YAK someone in the back has a medical issue
I called medlink and this was easy for me since almost every flight out of ANC or FAI has some unhealthy person who tries to die
Medlink determines the PAX is fine, for now.
ATC calls for a route change
FAs call and PAX has gotten much, much worse. Medlink recommends a diversion to JNU as there is a state hospital there.
Divert to JNU, ask FO to slow the aircraft down. He was all gouged up and knew he had to do it anyway.
Program FMC for JNU, call dispatch, call FAs make PA
Set up the RNP for 08 weather and winds are good enough for this best option
Descend through severe icing
Captains PITOT caution light
Captains airspeed fails with associated lights/errors
Autopilot disengages
Memory items for unreliable airspeed
Run several page long checklist for unreliable airspeed/FMC is degraded
Switch to LDA 08 and hand build missed approach into FMC
Additional ATC reroute
Build entire approach again and missed
Approach needs to be flown as a VS/LNAV
Still not done with a checklist, can't remember which one
My FO did a great job but when we broke out at 3000' or so I had to talk him through the landing at JNU, since he's a 6 month guy he'd never seen it IRL. I was pretty busy pointing out the lights through the cut, the cut and giving very explicit instruction to not get too high in the turn to final.
I apologized for micromanaging but he didn't mind it's hard to see the lights for the runway in the sim and the flight through the cut is kind of not what you'd expect to see at a major airline...
At the 3/4 point of this monstrosity I just went into triage mode and I didn't build the approach perfectly the second time but I ran out of F's in my F's jar. So we had to identify one waypoint via DME. I got a bit of feedback about that.
I also skipped a waypoint on a J route. During one of the reroutes because it was just direct anyway. Also got feedback about that.
As always I just sat there and said oh yes mighty instructor I have so much to learn through the debrief. When in reality I probably would have just done what our director of safety did and just continue on to SEA. I actually experienced this out of FAI in real life and Medlink just kept us going to SEA. JNU was looking possible but awful and the captain agreed we probably should divert into there.
Lives of the many vs. the few and all.
