So as a fairly new Airbus 320 FO, I have a question that is stumping me. It's also my first Autothrust or even autothrottle airplane.
A manual I have says something to this effect. 'The FADEC computes the thrust rating limit for each thrust lever position. If the Thrust Lever is set in a detent, the FADEC selects the rating limit corresponding to this detent. If the thrust lever is set in between two detents, the FADEC selects the rating limit corresponding to the higher detent'.
But then in another manual titled 'Airbus A320: An Advanced Systems Guide', it says this...'When the Thrust Levers are set between two detents, the limit value displayed is based on the upper detent, but the actual value corresponds to the ACTUAL POSITION(my emphasis) of the thrust levers'.
So my question is this...when you are landing with Autothrust engaged, in the flare, (and get the corresponding RETARD aural alert), you then pull the thrust levers out of Climb detent and into Idle detent(disconnecting auto thrust). When is the actual EPR of the engines being reduced to idle? According to the first manual I referenced above, it won't be until you are in Idle detent. In Other Words, you are doing nothing in between the two detents, until you get to Idle. According to the way I am reading the second manual I quoted, it will be when the Thrust Lever Angle matches the actual EPR, because the Thrust Lever is acting as a Thrust Limiter. So in this scenario, you are actually doing something in between the two detents, because the rate of EPR decrease will be directly proportional to the rate you bring the Thrust Levers back(of course once your Thrust Lever Angles match actual EPR).
Hope my question is clear. Practically speaking its not really a big issue on landing, since EPR is probably almost Idle anyway. But this is just to enhance my understanding.
