BEEF SUPREME
Because you’re old
Yeah I’ll only have 24 years in at retirement…
Because you’re old
*Desired retirement I'll have 20. Mandatory, I'd have 26. None of us going to have cherry picked Seattle day trips on the weekdays in SEA.
You’re old too I guess…
Can’t use this phrasing, even with an aviation context anymoreAI training dudes
theaircurrent.com
Well, short of aloha snackbar pulling the fuel cutoff switches in tandem shrooming AS jumpseater style, it'll be very interesting to learn what human input can cause this. If any.I think most people had the feeling it was going the way of pilot error. The Dreamliner has been around for over a decade now and both jet engines don’t just quit at ~400 ft in the air.
Did we solve it yet? We needed to know within 24 hrs of the crash, I can't believe it's taken this long!!!!![]()
Oh, and wrong religion.
Most of the Indians I’ve met are Muslim.![]()
Still quite speculative at this point, no?Saw this pop up on the feed:
Air India crash investigation focuses on movement of engine fuel control switches
Data from the Dreamliner’s black box points investigators towards improper, inadvertent or intentional pilot actionstheaircurrent.com
What evidence is there of an engine failure? There were no conspicuous signs of an engine failure (no sounds, sparks, flames, flock of birds seen, etc.). Based on my reading of others' comments on this threat, the loss of or manual shutdown of an engine would cause momentary, visible oscillations before flight control surfaces are manually or automatically corrected to account for asymmetrical thrust. From the videos available, there does not appear to be any yawing motion. Additionally, the pilots do not indicate on ATC audio that there's an issue with a single engine, nor have any directives been published regarding checking engines on other 787s.
From the available crash footage, to my untrained ear, it sounds as if the engines are producing thrust (I'm not referring to the distinct RAT sound), albeit significantly reduced thrust. If the fuel feed to both engines were manually shut off, I suspect one wouldn't hear any thrust coming from the engines. The article also says mechanical failure is not suspected.
Surely, the PNF would notice if they turned off the fuel supply to the wrong engine. Surely, the 787's systems would be screaming that the good engine had no fuel supply. If both fuel switches were manually turned to off, this would have to be intentional, right?
I wonder if the AAIB normally releases a transcript of the cockpit voice recorder during the investigation.Ostrower is one of the more respected folks in the industry - if he's writing on it, it's because he has a pretty strong source.
