NovemberEcho
Dergs favorite member
Agree. I don't ever remember a time when an RA didn't overrule an ATC clearance.
I’d always heard it was optional on the pilot to listen to the RA or ATC and after this RA became mandatory
Edit:
This is from the wiki. More that it was contradictory in the manual
The accident raised questions as to how pilots must react when they receive conflicting orders from TCAS and ATC. TCAS was a relatively new technology at the time of the accident, having been mandatory<a href="2002 Überlingen mid-air collision - Wikipedia"><span>[</span>Note 2<span>]</span></a> in Europe since 2000.<a href="2002 Überlingen mid-air collision - Wikipedia"><span>[</span>4<span>]</span></a><span title="Page / location: 45">: 45 </span> When TCAS issues a resolution advisory (RA), the pilot flying should respond immediately by directing attention to RA displays and maneuvering as indicated, unless doing so would jeopardise the safe operation of the flight, or unless the flight crew can assure separation with the help of definitive visual acquisition of the aircraft causing the RA.<a href="2002 Überlingen mid-air collision - Wikipedia"><span>[</span>35<span>]</span></a>
In responding to a TCAS RA that directs a deviation from assigned altitude, the flight crew should communicate with ATC as soon as practicable after responding to the RA. When the RA is removed, the flight crew should advise ATC that they are returning to their previously assigned clearance or should acknowledge any amended clearance issued.<a href="2002 Überlingen mid-air collision - Wikipedia"><span>[</span>35<span>]</span></a>
While TCAS is programmed to assume that both crews will promptly follow the system's instructions, the operations manual did not clearly state that TCAS should always take precedence over any ATC commands.<a href="2002 Überlingen mid-air collision - Wikipedia"><span>[</span>4<span>]</span></a><span title="Page / location: 103">: 103 </span><a href="2002 Überlingen mid-air collision - Wikipedia"><span>[</span>BFU 12<span>]</span></a> The manual described TCAS as "a backup to the ATC system", which could be wrongly interpreted to mean that ATC instructions have higher priority.<a href="2002 Überlingen mid-air collision - Wikipedia"><span>[</span>4<span>]</span></a><span title="Page / location: 80">: 80 </span><a href="2002 Überlingen mid-air collision - Wikipedia"><span>[</span>BFU 13<span>]</span></a> This ambiguity was replicated in the Tu-154 Flight Operations Manual, which contained contradictory sections. On the one hand, chapter 8.18.3.4 emphasised the role of ATC and describes TCAS as an "additional aid",<a href="2002 Überlingen mid-air collision - Wikipedia"><span>[</span>4<span>]</span></a><span title="Page / location: 53">: 53 </span><a href="2002 Überlingen mid-air collision - Wikipedia"><span>[</span>BFU 14<span>]</span></a> while chapter 8.18.3.2 forbade manoeuvres contrary to TCAS.<a href="2002 Überlingen mid-air collision - Wikipedia"><span>[</span>4<span>]</span></a><span title="Page / location: 103">: 103 </span> The BFU recommended that this ambiguity should be resolved in favor of obeying TCAS advisories even when these were in conflict with ATC instructions.
