NC_BE300
I have aborted a T/O in a C150. On this airplane (built in 1974), the pitot tube has a metal flap attached to the assembly. During T/O roll, when the speed is great enough, the airflow over the tube fits the top part of the flap, and opens up the pitot tube. After advancing the power, checking the instruments, etc, it wasn't long before the C150 was ready to lift off because I was at a low T/O weight. I could feel the airplane wanting to fly, a quick check of the airspeed revealed ZERO. Pulled the power to idle, advised the tower, and taxiied back for another try, just in case the metal flap was stuck on that run. During the second try, I watched the metal flap on the wing during T/O roll, and sure enough, it wouldn't come off the pitot tube. I then aborted again, taxiied in, and removed the metal flap attachment myself from the pitot tube (which was only attached by what looked like a bobby pin). After that, everything was fine.
