We have standard pre-takeoff briefings for both single and multi-engine.
Single:
Should we experience any unusual noises, vibrations, or loss of power on the takeoff roll, we will immediately close the throttle and abort the takeoff.
Should we experience an engine loss with insufficient altitude, we will immediately pitch down to maintain airspeed, pick a landing point within 45 degrees, pitch to that landing point, and configure the airplane.
Should we experience an engine loss with sufficient altitude, we will pitch down to maintain airspeed and evaluate our options. (Meaning possible return to the airport, emergency checklists, landing point selection, etc.)
Multi:
Should we experience any unusual noises, vibrations, or loss of power on the takeoff roll, we will immediately close the throttles and abort the takeoff, maintaining directional control with the rudders.
Should we experience an engine loss with sufficient runway remaining and the gear are down, we'll step on the ball, pitch level, wings level, adjust the throttles as required, and land straight ahead.
Should we lose an engine with insufficient runway remaining or the gear are up, we will step on the ball, pitch level, wings level, mixture, prop, and throttles full forward, flaps up, gear up, identify - dead foot dead engine, verify using the throttle, feather using the prop control, and return to the airport for landing. (If we're at a safe altitude, we would use our emergency checklists before feathering.)
Single engine retracts use a combination of the two that incorporates the gear aspects of the multi briefing into the single engine briefing.
The above is said immediately before contacting the tower for takeoff clearance or announcing on CTAF for every takeoff except for go-arounds and touch-and-gos.
