Sprint100
Rotax Engines use a reducer, as do many others. Remember, this is for homebuilt aircraft, so the FAA doesn't care, at all. Again, you have no real proof, just your opinion.
Thank You
Seriously, what is your obsession with the Renesis, an engine that is clearly NOT built to aircraft specs?
I know when you're bumping around in turbulence the load on the propellar is changed with every climb and descent and there are hundred of small ones during every flight. The power setting is probably going to be high a mazda probably uses 50hp cruising down the highway but a cessna for example with 160hp engine at a conservative cruise setting of 65% is going to use 104hp.Automotive engines may not be expected to run at constant throttle settings for extended periods, but that actually creates a lower amount of stress on the engine than continually changing throttle settings and varying loads. Regarding a propeller mounted on a Wankel, you seem to be neglecting the fact that any engine sees gyroscopic forces. Flywheels aren't light.
There is a key design feature of the Wankel that you're overlooking Killtron. You feel more comfortable with a reciprocating Lycoming than a Wankel rotary. The forces exerted inside any reciprocating internal combustion engine far exceed those inside a rotary engine. The rotor in a Wankel never reverses direction, which results in a drastic reduction in forces seen on the rotor when compared to a comparable piston engine. You can see this for yourself by calculating the piston velocity at any given power setting for a reciprocating engine, and then calculating the forces exerted by acceleration when the piston changes direction at the end of each stroke. This happens thousands of times per minute and the stresses are seen on the piston, wrist pin, rod, cap, rod bolts, crankshaft, etc.
I'm not attempting to knock the standard piston engines we use today, but merely trying to show you a mechanical comparison. In addition, I'd suggest looking at NTSB reports involving Wankel engines. You'll notice that there are a relatively small number of failures associated with the converted automotive engines. I feel safe behind a Lycoming, but even I believe it's more likely to suffer a mechanical failure than a Wankel engine.
Interesting notes:
Curtiss-Wright was one of the first to have license for the Wankel. You might know the name as being associated with aircraft. Their RC2-60 Wankel engine powered an experimental Lockheed aircraft for the military. The soviets also used the Wankel engine to power aircraft, including helicopters.
...I never tried to design an engine.
Rotary engines just are not as efficient at utilizing the most power per drop of fuel like a piston engine is. I will bet you dollars to donuts that the FAA is not going to like your proposed engine swap. You are sacrificing tons of safety for just the ability to say you swapped an engine. You said it yourself, you have to put a speed reducer in between the engine and prop, which says in itself that it will be even more inefficient since you are literally dumping a chunk of that power.
A reciprocating engine is designed to handle those stresses. I'm sure there are thousands of G's on those pistons but they can sustain that. Airplanes also have flywheels and I would imagine the propeller being heavier and most of it moving faster than the flywheel has much greater forces exerted on it. I'm not saying the wankel will fail straight out of the gate but under some combination of wear and circumstances who knows what will happen. There are dozens of AD's out for every model of lycoming because even the engineers couldn't imagine every possible problem that might come up for even a purpose built aircraft engine.
Like I said before I can only think of a few problems with this I'm sure there are a lot more that I miss because I never tried to design an engine.
You haven't designed an aircraft engine either and there is probably a level of understanding you aren't even aware exists.There ya go:laff: Years of use and approval doesn't count for anything. Oh yeah, I forgot that airplane engines use that special metal, alloy-carbohydrate
P.S. - Any engine will fail with the right loads and stresses on it.
...Or maybe not. I don't know what your credentials are, but airplane engines and the engineering behind them are pretty dang simple, especially compared to something like the V-TEC engine in your average Honda.You haven't designed an aircraft engine either and there is probably a level of understanding you aren't even aware exists.
Apples and oranges.There was also widespread use in WWII aircraft, and I wouldn't say those were lacking in power.
Yes but that doesn't necessarily mean the engine can handle being run at 65% of its power for hours and hours without a problem developing. There are all kinds of things you and I don't even know about that can wear parts out from some combination of vibration and heat or whatever that the part wasn't meant to handle.Did you read my statement about running engines at constant power settings in comparison to the stop and go abuse an automotive engine endures?
How?Apples and oranges.
Yes but that doesn't necessarily mean the engine can handle being run at 65% of its power for hours and hours without a problem developing. There are all kinds of things I don't even know about that can wear parts out from some combination of vibration and heat or whatever that the part wasn't meant to handle.
Exactly so why use an engine that was meant to handle different loads and stress under different conditions. Do you really want to risk having your last conscious thought being "damn killtron was right"?Any engine will fail with the right loads and stresses on it.
Because if you take a 1500 hp engine and the gear reduction rob a few horsepower it isn't noticeable but might be with a much smaller engine. [/QUOTE]How?
Oh yeah...Fixed that for ya...![]()
HP = (Torque (ft-lbs) x RPM)/5252
And this gear drive operates with 100% efficiency? I know power is the rate at which you can do work. And I know what those terms mean and I know the BASICS of how all this stuff work just like you I suspect.You don't seem to understand how a gear reduction drive works. It does not rob horsepower. In fact, HP is a contrived number.
Well...no, but it's not really that bad. The benefits of the increased power available outweigh the slight decrease in efficiency.And this gear drive operates with 100% efficiency? I know power is the rate at which you can do work. And I know what those terms mean and I know the BASICS of how all this stuff work just like you I suspect.
So it does rob horsepower?No, nothing operates with 100% efficiency.
But you realize your perspective has downgraded from "it's going to fail because it's not designed for it" to "well, it's being robbed of too much power!" You've spent a lot of time qualifying your statements with words such as might or suspect and that's representative of understanding the basics. However, don't presume to guess what I know.
