Sprint100
I am reading up on the actual conversion from an automotive engine to a aviation engine. Here are two comparisons I always get asked about.
What is the cost and what is the exact weight.
Q. What is the cost to install the rotary in an aircraft and how long does it take?
A. It is impossible to say what any given builder will spend on their engine installation. The exact cost will depend a lot on how resourceful you are. For example, if you order custom heat exchangers from Griffon for radiators & oil coolers, you could easily spend over $2000. I used automotive air conditioner evaporator cores from the junkyard and spent $10. Intelligent use of available materials like this does not mean you are looking for trouble. I have no argument with those who insist on using the very best on their airplane. Here at Real World Solutions, we have one Guiding Principle on the subject: It is better to fly a good airplane than to dream about a perfect one. My total installation costs in 1995, was around $5000 including initial cost of the engine, redrive, engine instruments, cooling system, engine overhaul, exhaust system, etc (i.e. everything). Time-wise, I spent 4 months (almost 40 hours a week) designing, procuring parts, fabricating & debugging the installation.
For another point of reference, to replicate the Renesis installation on my RV-4 would cost about $12,000. Not cheap, but a lot less then an IO-360 Lycoming at around $30,000 (July, 2004).
Q. How much does the rotary weigh?
A. Weight was one of the primary reasons I chose this engine. The only thing that really counts is what the total system with re-drive, cooling systems, engine mount, etc weighs. This is called firewall forward (FWF) weight. In my case, this is about 345 pounds. From my research, it appeared to be the only auto engine available which would equal the weight, power and reliability of the O-320 or O-360 Lycoming. ANY automotive V6 piston engine will be much heavier.
Update 7/31/04: By careful attention to details, I have reduced the FWF weight by about 30 lbs in the Renesis installation.
Here is the breakdown of system weights in my airplane. This list is a bit out of date because it does not reflect many changes I have made (like the EFI system) but will give you a good idea of what you can expect.
<!--mstheme--><TABLE borderColorDark=#003333 cellPadding=3 align=center borderColorLight=#66cccc border=1><COLGROUP span=2 vAlign=top align=left></COLGROUP><TBODY><TR><TD width="50%"><!--mstheme-->[FONT=Arial, Helvetica]Mazda 13B Engine Core<!--mstheme-->[/FONT]</TD><TD><!--mstheme-->[FONT=Arial, Helvetica]180 lbs. (incl. water pump)<!--mstheme-->[/FONT]</TD></TR><TR><TD width="50%"><!--mstheme-->[FONT=Arial, Helvetica]RD-1B<!--mstheme-->[/FONT]</TD><TD><!--mstheme-->[FONT=Arial, Helvetica]42 lbs.<!--mstheme-->[/FONT]</TD></TR><TR><TD width="50%"><!--mstheme-->[FONT=Arial, Helvetica]Starter (RX-7)<!--mstheme-->[/FONT]</TD><TD><!--mstheme-->[FONT=Arial, Helvetica]7.5 lbs.<!--mstheme-->[/FONT]</TD></TR><TR><TD width="50%"><!--mstheme-->[FONT=Arial, Helvetica]Alternator (Mazda 70Amp)<!--mstheme-->[/FONT]</TD><TD><!--mstheme-->[FONT=Arial, Helvetica]9 lbs.<!--mstheme-->[/FONT]</TD></TR><TR><TD width="50%"><!--mstheme-->[FONT=Arial, Helvetica]Evaporator Cores (Qty. 2)<!--mstheme-->[/FONT]</TD><TD><!--mstheme-->[FONT=Arial, Helvetica]7 lbs. (total)<!--mstheme-->[/FONT]</TD></TR><TR><TD width="50%"><!--mstheme-->[FONT=Arial, Helvetica]Oil Cooler (stock Mazda)<!--mstheme-->[/FONT]</TD><TD><!--mstheme-->[FONT=Arial, Helvetica]8 lbs.<!--mstheme-->[/FONT]</TD></TR><TR><TD width="50%"><!--mstheme-->[FONT=Arial, Helvetica]Intake Manifold + fuel rails<!--mstheme-->[/FONT]</TD><TD><!--mstheme-->[FONT=Arial, Helvetica]8 lbs.<!--mstheme-->[/FONT]</TD></TR><TR><TD width="50%"><!--mstheme-->[FONT=Arial, Helvetica]Coolant (7 qts.)<!--mstheme-->[/FONT]</TD><TD><!--mstheme-->[FONT=Arial, Helvetica]14 lbs.<!--mstheme-->[/FONT]</TD></TR><TR><TD width="50%"><!--mstheme-->[FONT=Arial, Helvetica]Ignition Coil Assys.<!--mstheme-->[/FONT]</TD><TD><!--mstheme-->[FONT=Arial, Helvetica]2.5 lbs.<!--mstheme-->[/FONT]</TD></TR><TR><TD width="50%"><!--mstheme-->[FONT=Arial, Helvetica]Total Engine Weight<!--mstheme-->[/FONT]</TD><TD><!--mstheme-->[FONT=Arial, Helvetica]278 lbs.<!--mstheme-->[/FONT]</TD></TR></TBODY></TABLE><!--mstheme-->[FONT=Arial, Helvetica]<!--mstheme-->[/FONT]<TABLE borderColorDark=#003333 cellPadding=3 align=center borderColorLight=#66cccc border=1><COLGROUP span=2 vAlign=top align=left></COLGROUP><TBODY><TR><TD width="50%"><!--mstheme-->[FONT=Arial, Helvetica]Exhaust System<!--mstheme-->[/FONT]</TD><TD><!--mstheme-->[FONT=Arial, Helvetica]8 lbs.<!--mstheme-->[/FONT]</TD></TR><TR><TD width="50%"><!--mstheme-->[FONT=Arial, Helvetica]Engine Submount<!--mstheme-->[/FONT]</TD><TD><!--mstheme-->[FONT=Arial, Helvetica]7 lbs.<!--mstheme-->[/FONT]</TD></TR><TR><TD width="50%"><!--mstheme-->[FONT=Arial, Helvetica]Main Engine Mount (Modified RV-4)<!--mstheme-->[/FONT]</TD><TD><!--mstheme-->[FONT=Arial, Helvetica]15 lbs.<!--mstheme-->[/FONT]</TD></TR><TR><TD width="50%"><!--mstheme-->[FONT=Arial, Helvetica]Brackets, Hoses, et. al.<!--mstheme-->[/FONT]</TD><TD><!--mstheme-->[FONT=Arial, Helvetica]5 lbs.<!--mstheme-->[/FONT]</TD></TR><TR><TD width="50%"><!--mstheme-->[FONT=Arial, Helvetica]Oil (6 qts.)<!--mstheme-->[/FONT]</TD><TD><!--mstheme-->[FONT=Arial, Helvetica]12 lbs.<!--mstheme-->[/FONT]</TD></TR><TR><TD width="50%"><!--mstheme-->[FONT=Arial, Helvetica]Total Installed Weight<!--mstheme-->[/FONT]</TD><TD><!--mstheme-->[FONT=Arial, Helvetica]325 lbs. (Firewall Forward)<!--mstheme-->[/FONT]</TD></TR></TBODY></TABLE>
