So you show up to the airport, pick up your two inch thick jepp revision, and still push back in less than an hour?Mine are always up to date when I'm working. If you can't manage that, you shouldn't be in this career.
It's pretty easy to "do" a Jepp revision - just write it in as being completed on the tracking sheet they provide.
Can I use NOS charts?
Why on Earth would anyone want to do such a thing? And no, I'm not aware of any 121 carrier that uses those horrible things.
I know you're joking, but what they told us in initial is the inspector will look for a plate that was updated in the newest revision.It's pretty easy to "do" a Jepp revision - just write it in as being completed on the tracking sheet they provide.
I'm usually one or two behind. Thankfully we're finally getting rid of all of our enroute charts and alternate charts from our individual Jepp binders and getting a sealed "brick" in each airplane in case we need them. Revisions will be half the size from now on.
mine are always up to date...........thanks JeppView!
Enroutes, legends and tables are in each plane, but the LIDO charts alone are thicker and most are double folds (think Jepp 10-9 pages for big airports). So, even with the en routes out, they take up MORE space.
No cause I and every FO I fly with is up there crowding him out . . . I do it and make sure the FO has it done before we go . . .So you show up to the airport, pick up your two inch thick jepp revision, and still push back in less than an hour?
Is it lonely up there, on your pedestal.
