MikeOH58
I would imagine there being some sort of alarm when the plane sets up for a landing with the gear still up..This is old technology!... maybe i've been watching to much tv..
Theres generally three gear unsafe indications the pilot would recieve...
*Reducing power below a certain manifold setting
*Flaps extended to 20 degrees or beyond (varies with a/c)
* Below a mininum indicated airspeed
Even if the guy had the emergency gear extension in the off position, he still should have had an audible warning comparable to a stall warning but worse...If not the audible warning, his visual warning would be the gear unsafe blinker, but if he failed to see three green, then theres no way he would have seen that.
If this guys airplane was capable of giving gear unsafe indications then I sure as hell hope there was a malfunction, and this wasn't due to someone pulling circuits because they don't like annoying noises or blinky lights...
I really don't think theres any justification to a gear up landing due to pilot error. Sure, theres added stress and fatigue when flying long hours, hard IMC, and an unfamiliar approach, however, we have all been there before...Too me, a gear up landing is something along the lines of leaving your house, driving to work, and when you get in the office, people are just staring at you, because you forgot to put on pants or underwear, and you just realized it 45 minutes later.
Sucks for the guy, and i'm judging pretty harshly right now, but I do hope he can recover from this major mistake, and continue a career in aviation...It's all on him, and its going to take a lot more than telling an interviewer "I learned from my mistake"...If it were me, i'd be damn sure to be attending as many safety lectures/seminars as I could...I'd also try and write an article for aopa or some other type aviation outlet, detailing what happened, so others could avoid my own mistakes etc...
While i'm on the subject, i've got a major problem with people just using "gump" check without a checklist. Last week, I was flying as a friend as a safety pilot...All he did was his "GUMP" check, and never bothered to take out his checklist...Well, heres the problem...He properly identifyed each item on the gump check; twice!...However, instead of actually putting the gear down, enriching the mixture, or putting the prop forward, all he did was run his hand over each item! Around 700 feet on final I told him to verify three green....Oops...
ohhh, one more thing that pisses me off...Instead of immediately adding power first and initiating a go-around, he calls tower to let them know what he is doing. Screw the tower! If you have to go around, then freaking go around! Call them after you add your damn power and are climbing the airplane! I've seen a lot of people do that....
boy oh boy, I can't wait to finish my CFI hehe
sorry for the jihadi hijack by the way
