TXaviator
10fpm = turns out bad with ###### tires supplied by UND
tires? i prefer using the wingtip as a skid plate to sorta get some friction to slow the plane down.
sounds like some of you guys need to practise the landings a bit.
-1000fpm = bad
-10fpm = good
Pahlease, you guys suck.... it's all about -0.000000000000000000000000000000000000000001 fpm .......smooth and sensual. Just like in bed.
:nana2:Oh no, the closest I have gotten to smooth and sensual in bed was with my Gleim publications. Shoots, there goes my chance to be a professional pilot like my idol Rod Machado!:nana2:
they are normal GA tires from my experience. if you want some good friction when you stop, you need to drop the flaps, the 40* of flaps are producing a lot of lift and not allowing full braking action.10fpm = turns out bad with ###### tires supplied by UND
Oh hey Mr. High and Almighty, you weren't in the airplane with us. It is known that UND has had a couple of problems with tires going flat and a receiving a bad batch of tires. Many of these tires happened to be thrown away. Save your blind bias and obsession for UND somewhere else. I guess UND is god in your opinion and can never do any wrong.are you joking? the UND bashing has stooped to the quality of tires on the planes?
get real.
is that why i watched a seminole get stuck over by flight support last week with a flat tire?Oh hey Mr. High and Almighty, you weren't in the airplane with us. It is known that UND has had a couple of problems with tires going flat and a receiving a bad batch of tires. Many of these tires happened to be thrown away. Save your blind bias and obsession for UND somewhere else. I guess UND is god in your opinion and can never do any wrong.
of course that is against UND SOP's..
its against SOPs to change flap position on the roll out?? (serious question)
why/whats the reasoning behind that?????
If you need to retract the flaps to safely get the airplane stopped on a true short field, you shouldn't be there in the first place. This brings a quote in mind an older pilot told me once. "I'm more impressed what a pilot won't do with what he can do."
Another reason I think UND doesn't do it (ie my opinion), you won't find many airlines calling for flap retraction to reduce stopping distance. Kind of like if you need the thrust reversers to stop in normal conditions then you shouldn't be attempting the landing in the first place. They become real beneficial with contaminated runways.
I know in the CJ3 we actually added more flaps on touchdown to increase drag and destroy life (speed brakes deployed when we moved lever into ground flap position).
NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER
did I mention NEVER!
Make a config change on the rollout, your attention needs to be 100% on the landing, not moving a lever (save for the reversers or spoilers). Slightly more complex airplanes have rudder effectiveness (ie the amount the rudder moves) tied into if or if not the flaps are deployed. Retracting the flaps could find you without enough rudder or noswheel authority to control the airplane in a crosswind or take more than you are used to putting in.
i think the PIM/POH says to do so to increase braking effectivenessIf you need to retract the flaps to safely get the airplane stopped on a true short field, you shouldn't be there in the first place. This brings a quote in mind an older pilot told me once. "I'm more impressed what a pilot won't do with what he can do."
