KBTL Hawker 800 crash
I’m not familiar with Honker heavy maintenance, does the wing get demated at some of the heavy checks like a Lear? Or does it seem more likely that the aircraft over stressed during a botched stall test?
I never flew one but they were around at a previous job. By all accounts they were built like a brick poop house.
They have to take the TKS panels off and evidently putting them back on is a bit of a delicate process. So then some poor dumbass (like,say,me) has to go stall and see whether it flips over and crashes.
I don't think that thing was missing a wing, but my eyes are getting old along with the rest of me. My money would be on pulling through the pusher and winding up in a deep stall.
didnt someone intentionally snap roll a hawker a buncha years back? my impression has always been they are brick sh thouses
They're built like they thought they'd never have to be disassembled. The deepest I ever got with a Hawker was removing/reinstalling the tail cap so we could remove/install the horizontal stab. I don't recall the actual amount of bolts that holds that entire tail together, I just remember trying to torque them properly and install the cotter keys in a difficult position repeatedly for days. I've always heard the rumor that that airplane in particular is as overengineered as it is because all of the old school engineers from WWII were kind of on the chopping block when the Hawker was being designed and they saw a Learjet land and went to have a look. Then they dropped acid and kept their jobs designing all sorts of steampunk nonsense like the landing gear. Go look at any jets MLG and it's pretty obvious how it works, do the same with a Hawker and you might spend some time scratching your head. I'm not saying it doesn't work, it's just overly complicated and that's why no one ever copied it. They are built like a brick • house, if that • house was in Willy Wonkas Chocolate Factory.
Tbh I didn’t watch it and was going off the impressions of others.
The TKS panels have stall "strips" mounted on them. Again my Hawker experience/knowledge is very limited and I hate working on them with a blind hatred. The airplane in question was at an airport with a big MRO onsite. It'd been there since March and this was the first flight since. I have no idea about what might've happened but it seems likely it was related to to whatever MX was completed. Has Duncan Aviation said anything?
I should also say the absolute easiest TFE731 engine change is a Hawker 800 with no thrust reversers. In and out in a day and a half, maybe two days if the wind's blowing too hard.
Maybe you'll get it but most likely I'm just wasting my time with you.
This post invokes strong feelings for you. For you. For you only. For nearly everyone else it's more of a *shrug* moment to "huhuh yeah bro". 99.9% of us could care less if our paycheck appliance is a steaming pile of poo poo or a real man's airplane.
You care a lot apparently. It matters to you. But those are inside thoughts. Keep them to yourself. Everyone else is just *shrug or *lol.
I’m happy if the important bits work and the flight deck doesn’t smell like socks and ass.
Thanks again to @CK for the "opportunity" to get my test pilot wings doing one of those!
Yeah, I remember doing some stall checks on the hawkers with Dumont lol... Those planes tried to off us before we even stalled them...
I have done a dozen Hawker stall checks. Everyone was different, but you always went into the procedure expecting a violent roll off. A strip of sealant missing between the TKS panels can make a difference between a normal event and hanging in the shoulder straps. If the upset develops into a spin you will not recover.
Alex.
Alex.
Happy I never had to do that and we traded our Hawkers for Challengers about a year after we got them. That baggage situation was interesting.
We were AOG in a Lear 45 with a bunch of guys headed out for a golf trip. Got recovered by a Hawker, I could feel their sorrow by the looks on their faces as we piled up all the crap this that these guys had packed along.
They managed to make it all fit though. I didn’t look to see how much was strapped to the seats though.
The earlier (true?) Lears, yes. The Bombardier-era Learjets not so much.
The majority of my LearJet experience was on models 24, 25, 28, 31, 35, 36, 55 and 60. I farted around a bit with the 40/45 and 70/75 but I don't think I know that much about them. I did get to walk through the 85 fuselage mock-up (it was a fiberglass thing on a low-boy trailer) before they pulled the plug. I'm not even sure how you'd remove the wing on a 45 but I've done it a few times on the earlier models. I have no idea how Hawker wings are attached but given my limited experience I'd guess it isn't easy to remove them.
I remember our mechanics bitching whenever a APU had to be changed out. You have to partially disassemble it in the hell hole to remove it. Then setups a large pulley contraption to get it out.
The pusher is activated by a somewhat archaic aoa detection system. The stall test is to make sure it activates prior to stall and, that you can maintain directional control until that point. The SRM allows you to use aileron to correct roll off. Roll of which is a wing dropping.
Back when I did my CFI spins in a 172, we had to use aileron to induce the spin. 🤷‍♂️ I see no correlation lol.
That being said on the full flap stall often the airplane will mush and not maintain pitch as it rumbles. People tend to give it extra pull to get the pusher- which is exactly what you’re not supposed to do. It takes a second for the stall valves to open. Between the pull and the pusher a wing will drop and boom over they go.
In my time at FSI I never heard of one that spun and was not significantly damaged in recovery- and many did not recover. Minor upsets were not as much an issues.
If you are doing these tests, don’t use aileron. If you can’t get it to the pusher at prescribed speeds, wave off the test - recalculate the speed based off actual weight and temp and if different than predicted take it back for adjustment. Don’t try to force it to the pusher. The hawker rudder is undersized for the plane. That’s why it’s got rudder bias for engine failures. Rudder bias doesn’t do squat for an airplane in a spin, and, the plane isn’t certified for spins.
