New Cessna 150 Owner
Usually tach time is used for aircraft and Hobbs time is for pilots. This is based on FAR definitions, by the way. However, at the 135 I worked at we used a Hobbs meters driven activated by air pressure to track aircraft time. So there are different ways to do it.
Ok, cool - I just wanted to make sure I hadn't bought an 8K hour airplane that actually has 10K hours on it.
Still possible, but on a C150 - that isn't much of a difference in value/ maintenance items as there are very few, if any, life limited components on the venerable Cessna Commuter. You'd have to audit the logbooks to verify the tach - hobbs - TTAF. TTE are consistent.
The newly overhauled prop ... $2,200 for the overhaul and another 3.2 in labor for my A&P to put it on:
