Murdoughnut
Well sized member
Dockets out. Interestingly, the CVR indicates they did get a TCAS warning before the collision, which I thought was inactive below a certain altitude.
The CVRs seems to indicate the CRJ saw it coming while the helo likely didn't, or at least not with enough time for an audible response. Helo crew knew they were high, which is interesting.
Sadly as already discussed most likely, DCA ops have TAs all the time which kind of makes them a "crying wolf" type of situation.RA is inactive. You’ll still get TAs, minus the aural below 500 I believe, if conditions are met.
It seems the helicopter crew was, unsurprisingly IMO, also having radio reception and transmission issues.The CVRs seems to indicate the CRJ saw it coming while the helo likely didn't, or at least not with enough time for an audible response. Helo crew knew they were high, which is interesting.
The field's 10lbs of poop or more in a 5lbs or less bag, with or without the helicopter operations in close proximity.I am reading the interviews and it is amazing how many people think knowing how to circle to 33 is good for DCA ops. Even after stating that ATC may only get an extra 1-2 departures in an hour as a result.
If it's the PSA interview transcripts (Exhibit 2-AIR-B) you're referencing, they're sitting in my downloads folder regardless of whether the Board wanted them out there or not.I think this was accidentally released. It appears to no longer be available.
Just talking about the main link. It no longer works.If it's the PSA interview transcripts (Exhibit 2-AIR-B) you're referencing, they're sitting in my downloads folder regardless of whether the Board wanted them out there or not.
I mean. Smart cars have high safety ratings but when Jeb hits you with his huge truck you will be turned into a slurry but the car will still be mostly intact.This is sort of an interesting one to me because the CRJ was relatively intact and they recovered nearly the entire aircraft and not in a billion pieces like a lot of these end up being. For instance, in the survivability doc, there's a picture of one of the FA jumpseats still intact and fully attached to a large piece of the bulkhead.
Blunt force trauma.This is sort of an interesting one to me because the CRJ was relatively intact and they recovered nearly the entire aircraft and not in a billion pieces like a lot of these end up being. For instance, in the survivability doc, there's a picture of one of the FA jumpseats still intact and fully attached to a large piece of the bulkhead.
Point being, it wasn't a high energy impact and the aircraft didn't incinerate itself after the impact with the ground. The mini liquor bottles in the serving carts survived unscathed. You don't typically see wreckage in this "good" of condition.I mean. Smart cars have high safety ratings but when Jeb hits you with his huge truck you will be turned into a slurry but the car will still be mostly intact.
Crude but sufficient.I mean. Smart cars have high safety ratings but when Jeb hits you with his huge truck you will be turned into a slurry but the car will still be mostly intact.
