BEEF SUPREME
STOP!!!!
The post “accident” investigation revealed that this Challenger flight was the 5th or 6th shuttle flight with a fuel leak. The leaks were known LONG before Reagan was President!
In some far left field position, I guess you could state that the TEACHER died because of Reagan pressure but clearly not ALL of the astronauts……. but even this statement would be both over dramatized and an overreach.
Yeah. Gonna have to just disagree with you. The temperature limits for the O-ring seals were well known and violated until this accident. Not sure where you are getting your information on a fuel leak but solid rocket boosters aren't going to leak. They will blow up when the hot gasses escape because of escaping hot gasses bypassing an O-ring that has a temperature limit. The temperature limits for launch are there for a reason:
"A lengthy investigation of the accident conducted by the independent Rogers Commission revealed a plethora of safety issues. Among the commission's findings were a flawed decision-making process for launch, and managers not fully appreciating the dangers of launching a space shuttle in cold weather. The ultimate technical cause was "destruction of the [solid rocket booster] seals that are intended to prevent hot gases from leaking through the joint, during the propellant burn of the rocket motor," the commission wrote."
This kind of behavior led author Diane Vaughn to coin the term "Normalization of Deviance." Below is more information about that:
"In the understanding of safety and risk, Vaughan is perhaps best known for coining the phrase "normalization of deviance",[5] which she has used to explain the sociological causes of the Challenger and Columbia disasters.[6][7][8] Vaughan defines this as a process where a clearly unsafe practice comes to be considered normal if it does not immediately cause a catastrophe: "a long incubation period [before a final disaster] with early warning signs that were either misinterpreted, ignored or missed completely."[9][10]"
So you can type STOP and use four (4) exclamation points and say I'm creating a far left theory but I'll just say "nice red herring". You are entirely missing the point. I'll just go ahead and type the point out clearly: Lots of flight departments and individual pilots are making this mistake on a daily basis. Nothing bad happened last time so we will do it again, even more. That is what NASA did and nearly every flight department that I have flown for.
This behavior needs to be kept in check at an organizational level or there will eventually be a disaster.
