Our flight? Was it FL490? We usually did 430-450. Occasionally we’d get a block and step climb higher. But yes, we also took the opportunity to practice an emer decent since we were just west of Catalina trying to make LGB and the controllers said go for it. We made it. I thought it was a front fan vibration issue?? That could’ve been another time though.
I’ve also been to 510 twice in a 45. SoCal to TUS. Empty. All the stock removed. VFR both ways and the right amount of fuel. Super light. Both on 02. It can easily be done safely. It definitely wasn’t a “let’s 410 it brah”. It was holding .76/.77 no problem. We did it in blocks and stepped climbed as not to get slow. The 45/75 series is a very capable airframe. Hopefully It will be supported in the future. Even if it’s not Bombardeir. Still one of my favorites after 3k’ish hours in it.
Edit to add: As you can see in the pic above as opposed to the OP pic. The OP pic was plowing through the air nose up and and the low speed tape is visible. The above pic is accelerating and no low speed tape. Technique.
