Autothrust Blue
”…trusting ze process…”
So many questions, so little time.Is there where I come for a loan for my kid's school?
Aren't the briefing guides in everyone's Jepp subscription anyway, so you can see at least on paper what you're getting into? I think the Vail plates were.I was junior manned into the LAX DMA program starting in August. Does anyone have any insights/experience with the training, scheduling (I'll likely be on DMA reserve), Aspen flying, etc.? Is Aspen flying really as hairy as everyone makes it out to be? Do DMA pilots still do regular line flying or is it all ASE trips?
SAAT 4 was not DMA; there were checkouts that you had to do for certain stations but it generally did not dictate your scheduling. North Bend (?) was/is SAAT 4, which required a supervised entry, but it was not DMA, for instance. I'm pretty sure, at least in my time there MMH was merely SAAT 4, Supervised Entry Required, and not DMA. DMA is a labor construction to replace the "Aspen program," which was, as expected, a pain in the Ass-pen.Before I left, some of the DMA flying included ASE, Eagle/Vail, Sun Valley, and maybe Mammoth Lakes? I went into MMH once as an FO but the captain only needed the training. Some of those might be seasonal and some, SKW might not even go to anymore.
I got awarded SLC DMA right before upgrade and it was similar there. At one point I looked at a DVR and it was all locals and stand ups with one 4 day pairing. It did get a bit better in the winter. I declined and took upgrade anyways as they told me they wanted me to commit November to April in the program.I do the DMA on the captain side in DFW. It's fairly recent here but so far I enjoy it. If it keeps me out of Lawton, I'll never leave the program. When I was an FO in Denver before they made the changes the ASE program was fantastic. It's okay now. Schedules are going to be highly variable based on the base. In DFW it is all locals, the other bases I know have very different trips. In the winter you can expect the schedules to change drastically.
There is no position freeze if you are involuntarily assigned, correct? My last interaction with this language was while it was still in draft form.Something to keep in mind for those FO'S who also want first upgrade. But I'm sure if you're junior manned that's a different situation.
HAha, OO and “language”.There is no position freeze if you are involuntarily assigned, correct? My last interaction with this language was while it was still in draft form.
“We’ll do whatever we want and what are you going to do about it TFAYD”
	Mammoth, sun valley, Jackson, and North bend are a captain checkout.SAAT 4 was not DMA; there were checkouts that you had to do for certain stations but it generally did not dictate your scheduling. North Bend (?) was/is SAAT 4, which required a supervised entry, but it was not DMA, for instance. I'm pretty sure, at least in my time there MMH was merely SAAT 4, Supervised Entry Required, and not DMA. DMA is a labor construction to replace the "Aspen program," which was, as expected, a pain in the Ass-pen.
What the "Aspen program" became, a cute little acronym - you're welcome for that new initialism, since there are/were other airports (EGE) that had special qualification requirements above and beyond a supervised entry.DMA?
Designated Mountainous Areas?DMA?
Close. Airports.Designated Mountainous Areas?
Aspen used to be all out of Denver, and all done with pilots bidding hard lines in DEN, and a bunch of other little things; they received a higher guarantee than the rest of the fleet and (etc.). Naturally, ASE has other service other than DEN, and you can see where that goes.
Close. Airports.
If there are any DMA pilots lurking around here, it would be awesome if you'd PM me.
Thanks all.
