horrific storms
I thought NovemberEcho and plenty of others had made it abundantly clear that you don't fly into something you don't like. That's not a question here, and shouldn't ever be. I fly in NY airspace multiple times daily. I fly entire legs under NY TRACON control (EWR-BDL, EWR-AVP). In seven years of doing that, I've had maybe two instances where those guys wanted to put me somewhere where I didn't want to be. Both times, we worked as a team to find a better route. I get frustrated with guys who don't see the big picture, want to go somewhere they can't, and then get mouthy on frequency about it. I think someone earlier mentioned that with TCAS we'd be fine. Wow. Sure, you may not have a mid air, but give an entire congo line an RA, and see how that works. Or, worse yet, blunder into a stack up over a hold. Often, when there's weather, these guys have a very narrow window to work your flight in. They take what you say seriously. If you say, "hey, that routing is not going to work" they are going to close that route down for the numerous aircraft in line behind you. If that's the last route into the airspace, guess what, the airspace is closed. Then comes the groundstop, and horrendous EDCTs. Now, if the weather has moved across the fix, so be it. But, if the controller is telling you that the routing is working, it might be worth a closer look. Basically, I'm saying that there's no room in the cockpit, or on frequency for an ego. Yes, NovemberEcho could have worded his IP a little better, but DON'T develop an ego around the fact that you are in charge of the airplane.
Well, there you have it. @Hammertime has dropped the hammer. Disregard at your peril you know nothing hacks!
I flew the NE airspace between Boston and DC almost exclusively for years not all that long ago, so I'm familiar with the frustrations of the area.
That said, I don't actually disagree with some of what you're saying. I agree that it is cringe-inducing to hear fellow "professional" pilots cop an attitude while an overworked controller is trying to stuff X amount of pounds of crap into an ever shrinking bag. I agree that TCAS is a tool, not a potential replacement for ATC. I disagree that I have an ego because 'I r pylit.' I'm focused on flying safely and legally. I fail to see where you find an ego problem in that.
However, my FOM dictates how close I can get to a storm being painted on our radar. My experience dictates how comfortable I am pushing those boundaries. As such, just because one airplane in front of me does something, doesn't mean I will follow suit. If that means the airspace ends up being closed well, then it closes. If we start holding, so be it. The northeast, or the entire east coast for that matter has no shortage of options for diversion airports.
Personally I feel for controllers. The experience level of most pilots using radar is quite low. Lots of guys deviate around Detroit, Chicago, Indy etc. And they deviate really far, 50-100 miles, screwing up controllers plans. The blowoff we go around in daytime is flown under or through all the time at night just because you don't know it's there.
I will say the onboard weather we now have is a godsend. You can make much more strategic decisions a lomg way out vs having to zig and zag.
That being said we also deviate around pop up clouds because the ride can be brutal sending carts up and people crashing down. ATC won't see those as they contain little moisture. They are normally located right on the centerline of an RNAV arrival.
One more thing, I would genuinely enjoy having more controllers go for rides with us. In my years of airline flying I've had precisely 1 in the jumpseat. Of my many controller friends, 0 have even tried yet almost every pilot I know has visited a tower/Tracon facility at least once. Perhaps more "seeing the other side" would go a long way here.
I've been on one FAM, but they're really kind of a PITA for us to get approved for. I can't speak for every facility, but most won't approve a FAM unless you already have the days surrounding your weekend off, which is hard to get unless you use your one time to bid leave in advance for the next year to set up a FAM, which most people won't do.
It was informative and I had a good experience and agree more controllers should try and get on one, but honestly most of the busier facilities staffing is so bad that it's really hard to get anything more than one day off, and using that rare extra offtime to sit in a cockpit and be reminded of work doesn't sound too great.
I do think it would be good for both sides to do more tours. If pilots could come to the facility and just watch a full shift and see what goes on and how little things can have huge effects on a Sector I think it would do a lot for awareness on that side of the mic, and vice versa.
I know personally one thing I took out of the FAM was how much of a pain reprogramming an arrival into the FMS can be, and I kind of adjusted the way I assign speeds and stuff based on that.
Anyone remember AirTran 426?
https://www.ntsb.gov/_layouts/ntsb....ev_id=20001211X10040&ntsbno=DCA98MA045&akey=1
We were right behind him on climbout. The controller told him that company had gone through the gap 30 minutes prior with no problem. He took that route. They offered us the same route.
THe captain elected to go upwind and around the long way. In his words, "That thing is a plane eating monster. I'm not getting within 30 miles downwind of it." It was a massive storm with an anvil at least 20 miles long.
As they started yelling "MAYDAY" on the radio, all he could say was, "See? What a bunch of assclowns."
Thanks for taking the time to explain that, I didn't realize it was such a PITA for you all. The one we had in the jump a while back made it sound somewhat painless.
Sent from my SM-G930V using Tapatalk
Don't know when you had your jump seater but pre-9/11 and post 9/11 are completely different programs for us. Post 9/11 is a much bigger pain with scheduling and paperwork. Plus they make us shave our beards and I just can't do that.
Hahahah. Not me but I'll give you dollars to donuts I know who it was. Can't remember the guy's name atm, but he had about half a pack's worth of teeth, was from somewhere south of Kentucky, north of Florida, and not heavily populated, and was utterly fearless in weather. You could watch him (and we did) on flightaware and he would drive straight through anything. Like, stuff he didn't need to. Air mass storms just sitting there...straight through. Always wondered what happened to him...
Once upon a time, when paper checks still had to get to the bank, when men were men (and so were women), when piston twins were top of the GA food chain, when single engine turbines were oddities, gods deigned to walk among mere mortals. And when they did, they were known as Freight Dogs. Their like is not to be found in the world today.
Every company has them.
In the early 90s when I was flying cargo in a Lance, we'd all mass launch on our routes in the early a.m. I had a pretty heavily loaded route, and another company plane launched in the same direction as me but to smaller towns and with a much lighter load. He would always pass me about 20 or so minutes after takeoff as I was just reaching cruise altitude. One day, as he was passing off my right side, he clicked the mic on company as per usual, and as I glanced over, he was passing by me in a wings level descent....inverted. Waggled the wings as he passed by, rolled it upright ahead of me, and pressed on to his destination.
There's always someone. He was leaving to a different job in a week or so.
Now it's "I gotta offline deadhead on a 777 now? Earlier it was a 787. I'll go through Bahrain instead as they have a better executive lounge!"
@Gonzo :)
Yeah, you're gonna need to shave your beard.... :-D
@bimmerphile, yep. JFK-900 captain!
  • Like
Reactions: bp
I had to get a little firm with a PHX controller the other night when the heading given to me afrer departure pointed me directly at a nice sized cell painting various shades of red and magenta. After a few exchanges, it basically ended in me saying "we need a turn now".
I've noticed this on more than one post of yours, not only are you wrong and not only are you on the wrong forum for your complaint but I've noticed your maturity level is pretty low as well.
I've said this once and I'll say it again. You work for us and not vice versa. Sorry if that comes off harsh. But it's the truth.
Enjoy your fat paycheck and sleeping in your own bed every night. We'll enjoy making decisions that you won't get an explanation for.
New guy here working toward my Aircraft Dispatcher Certificate.
I agree with what you said. My Dad is an airline pilot (17 years now) and personally I would want him to make the decision to go ahead or not. After all, its his ass up there in that plane. I'll always try to remember that when I finally go to work as a Dispatcher. I'll help the pilot see what I see on the screen, but it's his life potentially on the line. He's got to live with his decisions, but so do I.
