RDoug
I have yet to read a mishap where the accident could have been averted by aborting.
Air France 4590?
The Omega KC707 mishap at NAS Pt Mugu is a good example of a great decision to abort well above V1, actually beyond getting airborne. No chance that jet would have done anything other than cartwheel across the ocean had they not put it back down. That burned out hulk was laying off the left side of the departure end of the runway for a while (at least long enough for me to overfly it), and they all walked away. Burn up an engine to save an aircraft, and burn up an aircraft to save the crew/people……seems like a good hierarchy if the situation requires.
People don't often consider that. As I understand things through osmosis/listening to others around me, and please gents correct me if I'm wrong, the 121/135 world spends a lot of time standardizing things like this…..V speeds, RTO criteria, etc. While that construct certainly creates a simple decision matrix to alleviate the real-time decision making process, it also sounds like (at least based on MikeD's and other's commentary) scenarios other than engine failure become more ambiguous, when it comes to the "book". And that isn't a bad thing IMHO. They are ambiguous in other parts of the flying world too. But there is equally very little time to assess the correct decision at 140-150 knots on takeoff roll regardless of cause. You had better be damned sure that stopping the jet on the runway (or off) would have been better than dealing with it airborne. Based on the mishap reports I've watched over the years, there are many many examples of RTO's that became mishaps because they didn't take it flying. I have yet to read a mishap where the accident could have been averted by aborting. That might seem weird or unlikely, but that is at least my community's truth data. Of course there are differences between aircraft types, and I'm not speculating on what happened in this one, but I think it should be very clear in any pilot's mind that a high speed abort in a high performance/jet aircraft is perhaps the most risky emergency anyone is likely to encounter.
High speed below V1??From yesterday.
"A UPS United Parcel Service McDonnell Douglas MD-11, registration N277UP performing freight flight 5X-61 from Seoul (South Korea) to Anchorage,AK (USA) with 4 crew, was accelerating for takeoff from Seoul Incheon Airport's runway 33L at about 22:40L (13:40Z) when the crew needed to reject takeoff at high speed. The aircraft overran the end of the runway, broke through the approach lights and the localizer antenna and came to stop about 350 meters past the end of the runway on soft ground, the nose gear collapsed. The crew evacuated the aircraft without injuries. The aircraft received substantial damage."
http://avherald.com/h?article=4996a27a
Lol. How much thinking can you do in 2 seconds? 'Cause while you're doing it, you're covering almost 500 ft of runway!That's a good case study.
We've had a rash of high-speed RTOs for inconsequential bird strikes (windscreens, leading edge, etc.) In one case the RTO was initiated at 135 knots for a large bird that flew BY the aircraft and didn't hit anything. In each case, the captain has said that the runway was long, it was safer to reject, etc. etc. Or the worst thing I've heard, "I'll do it exactly the same next time, even though I know it's not SOP."
Every time I hear that I think:
1. This guy doesn't understand risk, or how risky a high-speed RTO is.
2. He also doesn't understand that the procedures are designed to eliminate or discourage the need for a captain to have to evaluate the risk in that moment.
There's no time to evaluate the relative risk as you near V1. Long runway/short runway/icy runway/wet runway...none of that should be in your thoughts. If you're above 80 knots, you're going flying unless you have a catastrophic engine failure prior to (5 knots before) V1. All the captain needs to know is the 80 knots call and the V1 call.
Doing a risk assessment at 135 knots is a recipe for a runway excursion.
Lol. How much thinking can you do in 2 seconds? 'Cause while you're doing it, you're covering almost 500 ft of runway!![]()
I think it boils down to knowing your aircraft and its peculiarities. There are a couple aircraft in which I brief a non-standard to the standard calls and aborts. "If we have a tire blow out above 80, but below V1, we continue the TO and take the problem into the air."
I was completely agreeing with you.Yep. That's my point.
Sometimes the bear just eats you. Not much to do in those situations except get lucky and make the right wager.
Engine failure is a reject, but almost every FCOM out there has some wording that approaching V1, it's probably best to continue and that by the time the decision is made after analyzing what happened, you'd be above V1. That's why at current Co. the V1 callout is actually made by the PM at V1 minus 5 kts.
There are some examples of RTOs that were the best possible outcome, but they typically don't get a lot of press. Allegiant had one in LAS that likely would've been a catastrophe if they hadn't rejected.
I have a technique to help mentally prevent myself from rejecting when startled, such as a bird strike. Below 80 knots I'm pretty much ready to reject. But above 80 knots I change the position of my hand on the thrust levers, and I think to myself, "we are going." It's kind of silly, but I've read so many reports where the captain is startled by a sparrow hitting the windscreen, and he rejects right at V1. I don't want that to happen to me.
Not too long ago I damn near ingested a Sandhill Crane walking across the runway in Orlando while doing about a buck 30. That SOB could do some damage! He seemed very nonchalant as he strolled in front of the plane.
Edit---I now see Cherokee's post about the Allegiant flight. Sorry to duplicate!
Curious. If you look at the FAR 1 definition of V1 and V2, it factors in the engine failure occuring at a speed below V1, defined as Vef. I guess it's not wrong to make your decision slightly earlier, but the ground roll distance following the engine failure will be greater than published if the failure occurs in that window below Vef.
If V1 is say, 140 knots, my hand is usually off the thrust lever by about 130 (-ish) knots.
