@Seggy
@Derg
@PeanuckleCRJ
Do you guys do the Tip Toe visual into 28L at SFO?
Part of it is going to the OAK radial at 14 DME. On can obviously build that using place/bearing/distance, eg, OAK/151/14.
But in our box, there's already a pre-made fix called "D331N" which is the typical format for fixes especially when you do an arc in Mexico. In this case, it's the DME off OAK, the 331 reciprocal of 151, and N for 14 DME.
Flew with my first kernel. The guy obviously doesn't like it. He asks how do you know it's the same point? So I showed by using the OAK/151/14 and it falls, obviously, on the same fix as the D331N. Instead of just accepting it (because it IS correct), he goes, "would you do this with a fed in the jumpseat?" I thought about it some, and then said yes I would. But I get the feeling obviously he's not comfortable so I just take out the D331N and put in the PBD01 pilot-built fix of OAK/151/14. Then he's apparently happy. He says he has no way of identifying that D331N fix, no lat long. [inside head thought] Well, Sir genius, you don't have a way of identifying the PBD01 we just built either. Bottom line, both ways are correct, but if you wanna be a kernel about it, go ahead. /inside head thought
I'm all about keeping the other guy as comfortable as possible so once I saw the resistance, I just did what made him for comfortable/happy.
More grrrrrrrrrr moments when on my leg I call flaps full at 165 knots (and slowing) at 1,500 AGL and he does, but then says I'm fast, and PULLS the spoilers to half detent. wtf? We would have been totally fine. 500 more feet to go for 1,000 and we would have definitely made it. Plus, at 1,000 we need full config and going for speed latest by 500.
And a few more items like that, I have to say inside I let slide. Were they dangerous or un-safe? Not really, control of aircraft was never in question. But don't pull the freakin spoilers on a guy without discussing it first.
The worst part was, you would think that at least he's good enough himself, but no. Several times I caught things he missed and twice he made the comment that he had been ashamed as CA and would commit seppeku (japanese knife to gut). A joke obviously, but I wonder if this set him up to mentally try and "get me" whenever he could? I suppose I should have said something. But being a small base of 53 guys and this being the first time, I guess I didn't want the bad rep right off the bat. But now that we have flown, next time he pulls this crap, I'll say something.
