Speed and acceleration
For a given aircraft mass the maximum rate of climb will occur when the
product of the speed and the excess thrust is greatest. As both thrust and drag vary with speed, there will be a particular speed at which this occurs (the best rate of climb speed) that is different from the best angle of climb speed. If the speed is increased above that for the best angle of climb although the climb angle will decrease, the rate of climb will initially increase.
If the aircraft is required to fly at different speed, the rate of climb will be reduced.
