z987k
The underlying point is a statement like "it likes to go fast" isn't true. It likes to go the speeds that are in the book, and climbing at .8 is not it. I've got a bit over 500 hours in the 700. Getting much slower than .74 and you were behind the curve, but climbing at .77 did not product a faster climb as one would expect because the best climb speed is not .77 nor .80 or .84. The people that flew it with the "it likes to go fast" burned a lot of extra gas spending a stupid amount of time getting to altitude instead of flying the numbers bombardier spent millions figuring out.Yeah, you're right, I'm not pulling this out from my own personal experience, just pulling it straight out of my ass. Just curious, how many hours do YOU have in a CRJ? Have you been "through the mill" at an airlines training department in, oh, say the last 6 months? Do you have access to speed cards that show you the ref speeds of a typical -200, or a -700, or even a -900? I do, and I'm actually looking at my company data.
And best rate of climb, as you should know, is NOT just a function of available wing. It's ALSO a function of available thrust. And as speed increases, so does the amount of thrust available.
An excerpt from one of the Navy pieces I read to wrap my head around a turbine engine better.
Source: http://www.netc.navy.mil/nascweb/api/student_guides/Eng_studentguide_18Jun2014 Change 1.pdf
I had a much longer reply posted, but decided to delete it. With your attitude, well, with your crass attitude, I decided not to post it. I'd be more than willing to discuss this, and why I believe the airplane that I fly, from my personal experience, climbs at a faster rate when going at a faster airspeed with someone who doesn't post things like "Does the CRJ have magic wings that cause best rate of climb to go UP (ref IAS) with altitude?"
Edit to add: If you can get ahold of some speed cards for the -200, have a peek at them. The approach speeds are higher than a lot of other equipment out there, at typical weights. I commute on 73's, 75's, 76's and 77's. They are slower on nearly every approach, by just about 10kts.
@CamYZ125 made a good point, the 200 doesn't have slats, so I would assume it does have a somewhat higher approach speed. Unless you were super light, speeds on the 700 are almost always in the 130s. On a ferry flight you'll see 125. Maybe a 73 driver can chime in, but I seem to remember those being pretty in line with the vast majority of domestic airliners.
