Envoy CRJ700 climb airspeed
Ha ha. I'd be lying if I said I haven't done that once or twice in the RJ.
It used to be a very common thing on certain runways when airports were running a certain configuration. 23/18L conflicts in CLT, 35/27R in PHL, 22 in LGA (all the time). Not a big deal really. Then along came FOQA and guys started getting paranoid about making low level turns like that.
Interestingly enough, in Hawaii NOBODY does S turns or requests a sidestep to another runway to avoid a go around. I've done it a few times not knowing any better, but the look on the captain's face (and the controller's confusion about what we were asking for) has pretty much dissuaded me from doing it too much.
Yep! It's virtually the same drag profile as the 757 and 767. Until you really get the flaps hanging out there, they are lift devices only. Boards mostly make noise but you've got to use them (they might give you 500 fpm depending)... if you don't, you'll be in another state before you get down! The exception is into JFK with the overhead pattern.... that's the only place that runs me around enough where I can get away with just floating down.
I flew the maddog for a bit (same wing that you're working with)- it was very similar to the CRJ in regard to flaps and drag (just as you described). We gotta get you on the big birds! :)
The lights have to add at least 500fpm for the amount of rumble and noise created.
